Water pump tension pulley - Defender Source
Old February 2nd, 2013, 10:12 PM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
Does anyone have some tips on how to loosen the water pump tension pulley to replace the belt? The pulleys pinch bolt sits right on top of the crank pulley and I am finding it impossible to get a flush 13mm socket on it. I've been able to get to it from the top with an extension, but because of the angle can't get a wrench or socket flush enough to turn it.
Old February 3rd, 2013, 07:48 AM
I may have removed the fan when I did that one. I dont really remember them causing much trouble, only the PS pump.
Old February 3rd, 2013, 07:52 AM
Cut the belt(s) off, which will give you some room to get at the tensioner bolt. You're replacing them anyway.
And it is a 1/2 inch not 13, at least all the ones I ever wrenched.
Old February 3rd, 2013, 01:53 PM
Surf90's Avatar
Surf90
C.S.
Do I have to remove the fan to get the crank / water pump belt off? I don't see how else I could get it off ( besides obviously cutting it, but that only solves half the problem )
Old February 3rd, 2013, 02:29 PM
I recall all the tensioners are a bitch. The belt setup on these is the pinnacle of British ingenuity.
I do it with a wrench. You might need a shorter one or at least 12 points to get the swing.
I don't recall having to remove the fan to do this.
Old February 3rd, 2013, 02:33 PM
Surf90's Avatar
Surf90
C.S.
Man, "a bitch" is an understatement. I feel like an idiot spinning my wheels down there. Bloody knuckles and frustration is all that I'm getting.
Old February 3rd, 2013, 02:56 PM
I'm sure gynecology and motor mechanics where the same subject at British schools in the 60's, 70's and 80's when all this crap was created.
Old February 3rd, 2013, 03:04 PM
Surf90's Avatar
Surf90
C.S.
Ha!! Yeah. Quote of the day.
That's hilarious
Old February 3rd, 2013, 03:08 PM
That's hilarious
When you do eventually get this done know that compared to the power steering belt this one is easy!
Old February 4th, 2013, 08:52 PM
Surf90's Avatar
Surf90
C.S.
Whoops. Meant to post this here (accidentally posted in tension thread):
I'm officially on day 3 of trying to get the idler pulley pinch-bolt loose for the crank belt. I've tried every tool at every angle and to no avail. I don't know what to do. I may have to drill it out from the opposite side?? I mean it is just sitting so tight on the alt pulley that I cannot get anything on it. I'm so frustrated.
Any last ditch suggestions??
Old February 4th, 2013, 10:24 PM
Post pictures... Does the workshop manual offer any clues?
Old February 4th, 2013, 10:46 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
We did this a couple weeks ago, and I don't recall it being that difficult. You might want to PM ArmyRover and see if he recalls any magic or voodoo that was involved. IIRC getting that bolt off was much easier than some of the others....
Old February 4th, 2013, 11:04 PM
Surf90's Avatar
Surf90
C.S.
Yeah I don't know if maybe the last time someone changed the bolts they rotated the pulley a bit much, but the bolt is virtually right on the alt pulley (barely enough room for the belt to pass underneath. I've tried every way from Sunday and I can't get it. Maybe if I can find a super slim wobble head socket, but it would have to be crazy slim. -- here's a photo from the manual, I would say the bolt on mine has half the space the image shows ..
Old February 4th, 2013, 11:34 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I'm thinking wrong belt size or incorrect routing.
X2 on removing shroud and fan. Replaced my water pump (and all belts and hoses) just a few weeks ago and the fan/shroud out opened a ton a room. I think I untied mine with a regular flat wrench. It should not be that tight. Are you sure you're turning anti-clockwise (sorry... Nothing personal... I so that myself all the time! ). I did this without a shop manual, so this is not rocket science (once you've done it once).
If your bolts are frozen, soak them in wd-40/liquid wrench/etc twice a day for 2-3 days in a row. Heat should really not be necessary (well... I should not have had to cut the bolt holding the starter neither... ).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old February 4th, 2013, 11:42 PM
psykokid
Jake
1997 Disco
Have you tried using a crows foot on a long extension? Might let you get enough leverage to break it loose. Also, +1 on using a good penetrating oil..
Old February 5th, 2013, 12:00 AM
Surf90's Avatar
Surf90
C.S.
Crows foot. That's a good call. I'll pick that up tomorrow. If that doesn't work ill pull the fan.
------ Follow up post added February 4th, 2013 09:01 PM ------
Good thoughts. Thanks! I've been soaking it in wd40 and turning lefty loosey, but really can't even get a flush turnable socket or wrench on it.
Old February 5th, 2013, 12:16 PM
psykokid
Jake
1997 Disco
I've found that Wurth Rost Off does a really good job as a penetrating oil for soaking tough fasteners, much better than good ol wd-40 or even PB Blaster..
Old February 5th, 2013, 12:32 PM
A mix of acetone and atf is supposed to be the best penetrant.
Originally Posted by pendy
I'm here for the D's
Old February 5th, 2013, 12:54 PM
Cut the belt off. Get a long piece of pipe or rod to use as a drift and whack the arm of the adjuster with a hammer to rotate it to a place where you can get a tool on it. Don't be spending days on that little SOB.
Old February 5th, 2013, 01:09 PM
Take the fan off... FWIW I've encountered two defenders that had the wrong pulley fitted so that the bolt hit the belt.
pulley, water, water pump
Water pump pulley wearing my coolant hose. 300 tdi sundogcwolfe Defender Technical Discussions 11 February 16th, 2012 12:29 PM
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Water Pump Help!!! Dfndr90 Defender Technical Discussions 14 May 3rd, 2005 11:51 AM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
