Water pump replacement - Defender Source
Old November 9th, 2003, 07:37 PM
mwmcgehee's Avatar
mwmcgehee
Michael McGehee
Unhappy Water Pump Change
I have just changed ou my water pump and have one concern that, perhaps, someone else has come across. When removing the bolts, one of the long ones (that go into the block itself) was covered in sediment. At first I thought the bolt was rusted, but after I cleaned it, there is no pitting or flaking. There was also no sediment in the radiator/cooling system, though the fluid was slightly discolored.
Any Ideas? Am I in for more problems down the road? Seriously, I have checked my manual and can find nothing on this. Thanks for taking the time to answer. mm.
PS., I checked the AQ's and found nothing simular.
Old November 10th, 2003, 03:15 PM
Did you try cleaning out the hole to see how bad it was in the bolt hole itself?
Old November 11th, 2003, 12:38 AM
mwmcgehee's Avatar
mwmcgehee
Michael McGehee
Yes, I cleaned out the bolt hole and got a little sediment. I also used a compressor to blow it out and applied an anti sieze compound.
Everything went together fine and there are no further leaks from the pump. I guess it may have been water intrusion into the bolt hole. I checked the old gasket and found that the installer had only put silicone gasket material around the outside of the casing and not around each bolt.
Thats my best guess, let me know if I need to do something differently. PS: any secrets to getting the system completely full again?
Old November 11th, 2003, 09:11 AM
Not sure what is the best way to fill the sytem. I have heard that parking facing uphill works. I would fill it, then drive a little, fill it some more if you can, then keep a gallon of collent with you for a little while just in case.
Old June 2nd, 2004, 11:35 AM
nykx
nick
1995 black #2456. 1994 yellow #922
water pump replacement
the bearing on my water pump is begining to go ... i already bought the replacement pump. any advise on the replacement proceedure? how long does it take?
thx -
Old June 2nd, 2004, 11:50 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Threads merged
Chris von C
[/size]
Old June 2nd, 2004, 12:00 PM
Hey Nick, check here http://www.defendersource.com/faq/En...ing.html#Pumps. I would give youself a day to do the job as it's a real pain sometimes to get the clutch fan off. Get some right stuff to put on all the long bolts.
Edit: Oh Good luck!
ac, water, water pump
Water pump replacement - help please JimC Defender Technical Discussions 2 May 23rd, 2007 12:50 PM
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Water Pump Help!!! Dfndr90 Defender Technical Discussions 14 May 3rd, 2005 11:51 AM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
