Water Pump Pulley Removal Help - Defender Source
Old February 16th, 2015, 09:51 AM
usadventureracing's Avatar
usadventureracing
Brett
110
I need to replace my water pump but cannot figure out how to remove the center nut (the center nut is round with a groove in it on "one side"). Is there a special tool I need? I have search the internet but no luck.
3.5 engine
I have no viscous fan.
I have a dual pulley.
The 4 studs on the water pump have no nuts on them so I am assuming the center nut is the only thing holding the pulley on.
1983 ROW D110
1970 Series III (Parting out)
Old February 16th, 2015, 06:06 PM
usadventureracing
Brett
110
Pictures
ID:	113926   Click image for larger version
1983 ROW D110
Old February 17th, 2015, 07:40 AM
usadventureracing
Brett
110
So no one has any suggestions? I was thinking maybe cutting the pulley off.
1983 ROW D110
Old February 17th, 2015, 08:05 AM
MileHighdefender90's Avatar
MileHighdefender90
Matthew Gaum
1967 Series 2A 109 safari wagon
Hey I have the same motor in my Range Rover 2dr when i get down to my shop i will take a look and see if i can come up with a plan that will help you in any way
Old February 17th, 2015, 08:55 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
It's been a long while since I did that on a vee-belt 3.5, but I thought the pulley came off after you took the four fan bolts out....
No?
KAA
Old February 17th, 2015, 09:01 AM
usadventureracing
Brett
110
The four studs do not, never had nuts on the studs, so I do not believe that is what is holding the pulley on. Unless it is rusted on and I am just lucky it has not come off.
1983 ROW D110
Old February 17th, 2015, 10:19 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
could it be bolted in from the inside????
good luck with your search
Old February 17th, 2015, 10:35 AM
UnfrozenCaveman
Keith Armstrong
Various
Shoot...it's not like the SD1 then?
http://www.rimmerbros.co.uk/Item--i-GRID008904
------ Follow up post added February 17th, 2015 09:40 AM ------
How about this one... http://www.rimmerbros.co.uk/Item--i-STC1611
Looks like there's (a) plenty of surface ares to rust on, and (2) some teeny fastners on the flange at the back.
Old February 17th, 2015, 05:24 PM
usadventureracing
Brett
110
Not bolted from the inside as there is no room. Just checked.
1983 ROW D110
Old February 17th, 2015, 07:31 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I don't know if it's different btw. a 3.5 and a 3.9 but on mine it's 4 bolts. Not studs, bolts. That's the only thing holding it on. Maybe someone snapped the heads off before you?
Old February 17th, 2015, 08:17 PM
I have no idea; but can you pull the water pump to get it off and look? I bet the boots sheered or only the belt is holding it on.
Old February 18th, 2015, 09:35 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Have you tried some penetrating oil & some gentle persuasion with a hammer?
I have a 3.5 in the Classic but it looks nothing like that pulley. Why do you not have a fan?
Old February 18th, 2015, 10:10 AM
usadventureracing
Brett
110
I have an electric fan.
1983 ROW D110
Old February 18th, 2015, 01:26 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Well that makes sense.
If it comes to itů. I can pull the pulley from my old RRC 3.5 for you.
Old February 18th, 2015, 05:48 PM
usadventureracing
Brett
110
No, please do not pull the pulley, but thank you. When it warms up a little bit I am going to remove the belt and see it I can remove it by tapping it off as maybe the bolts where just cut off and the tension of the belt is keeping it attached.
Thanks for all the replies.
1983 ROW D110
Old February 21st, 2015, 04:32 PM
usadventureracing
Brett
110
Got the pulley off, nothing was holding it on but rust and the belt. Anyone know what pump I have based on the pictures. I have included a picture of the pulley, it is a double pulley.Click image for larger version
ID:	114297Click image for larger version
1983 ROW D110
Old February 21st, 2015, 05:26 PM
cbfritz_03
Carmen
none
Is this it?...looks pretty close and I can't see the entire bolt pattern from your picture.
Rover V8 Landrover V8 Water Pump | eBay
Old February 21st, 2015, 05:33 PM
stc1611 up through 85 model year
Old February 21st, 2015, 05:46 PM
usadventureracing
Brett
110
Thanks so this is stc1611 there looks to be a difference or is mine missing parts?Click image for larger version
1983 ROW D110
Old February 21st, 2015, 05:51 PM
Thanks so this is stc1611 there looks to be a difference or is mine missing parts?Attachment 114307
aftermarket but same part no. Parts tend to change over 30 years. The pulley would simply bolt to the face of the one pictured.
pulley, water, water pump
Smaller NAS 110 water pump pulley mattm Defender Technical Discussions 2 July 12th, 2014 02:51 AM
300tdi water pump pulley Michael Wanted 5 May 30th, 2014 10:47 AM
Water pump tension pulley Surf90 Defender Technical Discussions 19 February 5th, 2013 01:09 PM
Water pump pulley wearing my coolant hose. 300 tdi sundogcwolfe Defender Technical Discussions 11 February 16th, 2012 12:29 PM
3.9 water pump pulley ZACHASS Wanted 1 December 2nd, 2008 09:25 AM
