Water Pump Pulley Removal Help - Page 2 - Defender Source
Old February 21st, 2015, 05:53 PM
usadventureracing's Avatar
usadventureracing
Brett
110
This would work with with pulley I have in the one pictures?
Thanks for your help!
------ Follow up post added February 21st, 2015 07:01 PM ------
Just saw the rest of your message.....thanks again!
1983 ROW D110
1970 Series III (Parting out)
Old February 21st, 2015, 06:10 PM
the pulley scenario varied with a/c non ac.
here's some pics on Rockauto. Pump is cheap.
RockAuto Parts Catalog[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=hgki12snsth1p4v62mls0e1v02
Old February 21st, 2015, 06:11 PM
cbfritz_03
Carmen
none
You're welcome... ..almost went to pull one just to answer you.
Old March 1st, 2015, 06:20 PM
usadventureracing
Brett
110
I removed my old water pump today and want to replace the bolts. Does anyone recommend were I could source them?
1983 ROW D110
Old March 5th, 2015, 05:31 PM
usadventureracing
Brett
110
I got the sct1611 water pump, but now my pulley does not fit on the pump. Anyone know what pulley would work?
1983 ROW D110
Old March 6th, 2015, 09:51 PM
mcoleman762's Avatar
mcoleman762
Mike Coleman
94 D90 ST/95 D90 SW/83 110
It looks like the pulley that you need to go with that pump is 602582. The pump you have there (STC1611) is the non-viscous type. Looking at your photos, you had the STC488 pump installed in your truck, which is for the viscous fan. Both pumps will fit your engine, but they use different pulleys and fans.
Hope this helps!
ID:	115441   Click image for larger version
Old March 7th, 2015, 02:19 PM
usadventureracing
Brett
110
Yep, I figured out what pulley I need for the new pump, now just need to find the new pulley. I called rovers north and the pulley is nla, they are looking to see if they can find one. I posted in the wanted section but no responses yet.
1983 ROW D110
pulley, water, water pump
Smaller NAS 110 water pump pulley mattm Defender Technical Discussions 2 July 12th, 2014 02:51 AM
300tdi water pump pulley Michael Wanted 5 May 30th, 2014 10:47 AM
Water pump tension pulley Surf90 Defender Technical Discussions 19 February 5th, 2013 01:09 PM
Water pump pulley wearing my coolant hose. 300 tdi sundogcwolfe Defender Technical Discussions 11 February 16th, 2012 12:29 PM
3.9 water pump pulley ZACHASS Wanted 1 December 2nd, 2008 09:25 AM
