Water Pump Issues - Defender Source
Old January 13th, 2011, 06:19 PM
OahuDefender
Jason
1994 D-90
Water Pump Issues
So to make along story short, I'm in the process of changing my water pump, t-stat, hoses etc. Lesson learned, if you change your fan clutch you might as well do the water pump too. A week after installing the new fan clutch the pump went bad dumping all of my coolant. That's a mistake I won't make again.
So, I'm in the thick of it right now and have hit a road block. I've removed hoses, 2 belts, fan and clutch. But I can't seem to get the water pump pulley to break loose from the pump. I removed the 3 bolts attaching it, but it just won't budge. I did a pretty exhaustive search and couldn't find any discussion of this. Do I need a pulley puller (and if so what kind works here)? Or am I just an idiot (wouldn't be the first time)?
I've thought about just going ahead and removing the pump, but I'd like to have more room and eventually I still need to get that pulley off the told pump. Also, any tips on removing the t-stat? Pretty tight space there and just wondering if anyone had a method that would make life easier.
Thanks for the help.
------ Follow up post added January 13th, 2011 01:22 PM ------
Should have clarified. 94 NAS D-90 with the 3.9. Thanks again.
Old January 13th, 2011, 08:45 PM
Naplm00
Matthew
hit it with a ball peen hammer? that what got my old bmw ones off
Old January 13th, 2011, 09:46 PM
OahuDefender
Jason
1994 D-90
Tried that, no luck
water, water pump
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Water Pump Help!!! Dfndr90 Defender Technical Discussions 14 May 3rd, 2005 11:51 AM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
