Water pump bolts - Defender Source
Old April 2nd, 2015, 11:11 AM
Water pump bolts
Helping Kent with a technical question. The bolts for V8 3.9 are all SAE aren't they? Or are the small ones metric? I can't remember. I'm pretty sure the two long ones are 5/16 x 4.75 and the long long one is 5/16 x 5". The smaller ones that just go into the front cover tho...those are metric or SAE?
Old April 2nd, 2015, 04:16 PM
my 3.5 was all SAE except for some of the accessory mounts. but everything bolted into or onto the engine itself is SAE
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old April 3rd, 2015, 07:49 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
My 94 v8 was metric if I recall correctly
Old April 3rd, 2015, 02:26 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I suppose I'll just go about this the old fashioned way, and trial and error it until I've sorted out all the bolts. No problem though, I have time as im still waiting on parts to arrive. Also still need to source an ignition harness, figure out my pulley/belt configuration, get my radiator re-cored or replaced, and figure out if I'll need new trans tunnel and seat box to fit the R380. Any leads or advice will be appreciated.
-Kent
1985 Land Rover 110 3-door ST
Old April 3rd, 2015, 03:09 PM
The floors/trans tunnel/bulkhead aperture/seatbox/driveshafts/ configuration is all driven by the position of the transfer box.
The stock V8/5speed (also 300tdi) setup puts the trasnfer box about 2 inches further forward than the old 4 cylidner setups which is what you have.
Putting everything 2 inches further forward like that means the transfer box wants to occupy the same spaces as the front panel of the seatbox. Hence the different parts for the two different setups.
The v8/5speed/tdi setup also puts everything about 1 inch further to the right.
You'll need to (well, you should) weld v8 engine mounts to your chassis after cutting off the 4 cylinder mounts.
if you do that and try to keep the 4 cylinder floors, you'll need to weld the mounts 2 inches back. Then you'll need to mod the 4 cylinder transmission brackets to move everything over 1" to the right. But then you'll have to massage the 4 cylinder transmission tunnel with a ball peen hammer to make room for the LT230 linkage. And you'll have to fuck with the foam or it will keep you form shifting out of difflock.
Ask me how I know all this.
Bottom line, you can buy the trans tunnel and bulkhead adapters pretty cheap. You can modify your existing floors and seatbox to work. You'll also need driveshafts. The front one can be from any disco 1 and the rear can probably just be lengthened 2" by any decent shop.
Then everything will fit as stock and you won't have to futz around too much.
I have my old EFI harness out of the classic. Works fine.
-Kent
Present:
1987 RRC- "Chewy 2"
Past:
Old April 3rd, 2015, 03:32 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Well that's a whole mess of brand new information and additional modifications I had absolutely no clue about. Awesome.
Old April 3rd, 2015, 04:30 PM
It's not as bad as it seems. I think I have the right bulkhead piece. You'll just need to source the tunnel or make one
Old April 3rd, 2015, 04:36 PM
Would be a PITA to make one.
Present:
1987 RRC- "Chewy 2"
Past:
Old April 4th, 2015, 08:10 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
What part of this whole process isnt a PITA?
bolts, water, water pump
Long threaded water pump bolts are seriously oily and dirty flananuts Defender Technical Discussions 0 April 26th, 2012 10:13 AM
Water Pump Help!!! Dfndr90 Defender Technical Discussions 14 May 3rd, 2005 11:51 AM
Water pump tensioner Mike Hippert Defender Technical Discussions 22 March 27th, 2005 12:16 AM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
Water pump replacement mwmcgehee Defender Technical Discussions 6 June 2nd, 2004 12:00 PM
» Defender Registry
Sandy
Sandy
Oliver
Squaretyre
Add your Defender
