Water pump bolt - Defender Source
Old February 11th, 2007, 10:21 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Water pump bolt
I've got a bolt that came out and now it won't go back in. I can get it all the way to where the threads in the hole are, but it won't thread in. It's one of the "long" bolts so it's not like I can cut new threads in the engine block.
I think I'm going to try to find a new one and/or recut the threads on the bolt.
Any other suggestions?
Thanks in advance
"It's not a Jeep"
Old February 11th, 2007, 02:09 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
I know the feeling, I am currently looking for one of the bolts that hold my water pump on my 200Tdi. It broke due to corrosion.
If you do find one let me know where.
Pat
Kirk Lazarus, Tropic Thunder
Old February 11th, 2007, 02:25 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Got a really small file? If you can find where the problem is on the threads, you can sometimes clean it up right at the spot of damage. I'd also run a known good bolt into the block to make sure you know which one is damaged.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 11th, 2007, 07:46 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
this link should help:
http://www.roverparts.com/Parts/STC483FK.cfm
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old February 11th, 2007, 09:44 PM
JBurt's Avatar
JBurt
Jesse McCoy
So what happens if it isn't the bolt???
Hypothetically of course...
"It's not a Jeep"
Old February 11th, 2007, 11:48 PM
Hans's Avatar
Hans
Hans Haase
If it's the block, not the bolt, I'd get my hands on a thread-cleaning tap (as opposed to a thread cutting tap). If a good bolt isn't even starting to grab, then it's most likely just the first thread, and an easy fix. But make sure it's a CLEANING/REPAIR tap, not the normal type. Both will work, but one has a much lower chance of 'oops' than the other.
http://www.tavia.com/cat2.html
Another trick would be to taper the nose of the bolt a bit, just the first couple threads, and see if it will start easily. But don't force it, just go gentle, after all the block is aluminum and not cast iron.
But before you try any of that, IIRC there are a couple other bolts that are the same thread and length, correct? I'd try a couple other bolts in the hole... sometimes you luck out and one will go in for you and clean the threads up.
-Hans
My oil line fix
Old February 12th, 2007, 09:51 AM
JBurt's Avatar
JBurt
Jesse McCoy
I did notice that everytime I pulled the bolt out it was covered in gunk, like the hole was full of mushy melted parts of the water pump gasket. I'd clean off the threads then do it again, always the same result. I'll get a new bolt and clean the threads.
Thanks all again, I'll continue to update on the progress
"It's not a Jeep"
Old February 12th, 2007, 10:44 AM
1/2in impact gun
Ron
Old February 14th, 2007, 10:36 PM
JBurt's Avatar
JBurt
Jesse McCoy
Eric fixed it, I am indebted
"It's not a Jeep"
Old February 14th, 2007, 10:49 PM
Defender13's Avatar
Defender13
Mike Lynch
1994 Defender 90 #1017
do you know what he did to get the bolt to take?
Mike Lynch
Old February 15th, 2007, 08:52 AM
JBurt's Avatar
JBurt
Jesse McCoy
I just put it in there and turned (seems to work for a lot of things on Valentine's day). The new bolt caught immediately.
"It's not a Jeep"
water, water pump
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Water Pump Help!!! Dfndr90 Defender Technical Discussions 14 May 3rd, 2005 11:51 AM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
Water pump replacement mwmcgehee Defender Technical Discussions 6 June 2nd, 2004 12:00 PM
