Water Leaks in the rain - Defender Source
Old March 31st, 2007, 01:43 PM
okyrover's Avatar
okyrover
Timothy Chesnut
1995 NSA Defender 90 SW
Hi I have a hard top D 90 that is leaking at the top left corner of the headliner , top of the door, and some were on the right side starting topside of the dash glove shelf. Is this a Defender thing or is something wrong? Both ruber mat fill with water.
Old March 31st, 2007, 01:48 PM
In England that would have been on the passanger side... So, they probably would not have cared.
I would check the seal on your sunroof. Once it stops raining, use a garden hose to narrow the search, then use some silicone to seal the leak.
Good luck and welcome to the board.
Old March 31st, 2007, 05:56 PM
Mine does that. If you had your headliner out you would see how the top is shaped to perfectly dump water out in that location. I'm 99% sure its not your sunroof. I think its water seeping through the gutter seal (take a look - there is sealant on the bottom the entire length of the gutter). Water seeps in through cracks in this sealant by capillary action and runs up the interior channel down the entire length of the roof, coming out the front corner when you brake or park downhill.
Old March 31st, 2007, 06:20 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
There was a german rainproofing guide kicking around on here a couple of years ago. Someone probably still has it (I looked, mine's gone)
"It's not a Jeep"
Old March 31st, 2007, 06:56 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
The right side top of the dash might be the vent seal. You can replace it with the foam strip or use a Series II rubber seal.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old March 31st, 2007, 07:00 PM
I've got the german-language "wasserhandbuch" which has some nice diagrams and stuff. Anyone who wants one can email me.
Look at the ECR site on one of the more recent D90 projects, they discuss this type of water infiltration and how they fix it.
water
AC water leak 89classic Defender Technical Discussions 2 June 12th, 2005 01:21 AM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Leaks - D90 Wagon Kimos Defender Technical Discussions 22 January 3rd, 2005 12:28 PM
Water leak Jon D' Defender Technical Discussions 1 September 5th, 2004 08:34 PM
