Water Leak bulkhead to windscreen frame seal - Page 2 - Defender Source
Old September 27th, 2012, 02:49 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Jack, I would be surprised if it was leaking from the point you indicated as any water leaking from there would run down the door seal lip.
If the water is right on the edge of the floor mat you should see a drip mark on the plastic trim covering the door check, you may find the leak point is actually the sharp crease in the door seal just below the point indicated.
Or as has been pointed out it is the vent flap seals that are leaking, the foam seals are not very good esp after 10yrs.
I have replaced mine with S3 rubber seals and through all the rain in the last few months the floor has been bone dry.
Try replacing the vent flap seals its the cheapest fix first, it's 2 fiddley M6 bolts and 2 pins use plenty of WD40 to remove the old seals from the flaps as it will cleanly remove the adhesive.
regards
Gren
Old September 27th, 2012, 03:11 PM
61rover's Avatar
61rover
John Crouse
Originally Posted by JackDEF90 View Post
61 Rover that sound good!
Yeah mine leaked there too. Do what Ron said and try and tighten the windscreen down. If that doesn't work then put a glob of strip caulk in there. That fixed mine. No rubber mat full of water any more.
Old September 27th, 2012, 04:47 PM
JackDEF90's Avatar
JackDEF90
Jack Nicholls
2002 Defender 90 station wag 2.5 D
People this is first forum I've ever signed on to and its been enlightening. Thanks for the advice, got a nice weekend coming so will give it a bash n feed back.
By the way, tightning the windscreen down.... Bit o plumbers tape on the bolt threads??? Can't do any harm!
Cheers,
Jack
Old September 27th, 2012, 05:39 PM
Grover's Avatar
Grover
Here is where the leak comes through. The inside and out
Make a gasket to put between the bracket and the wind wshield/bulkhead.
Old September 27th, 2012, 06:09 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Those bolts are the biggest pain in the backside ever. The captive nuts inside the flap like to move and you have to have your arm in the most uncomfortable position to access them. That said, it is worth the effort for the Series III rubber seals.
water
Pinion Seal Leak, Salisbury Diff Doug Defender Technical Discussions 18 August 8th, 2016 03:07 PM
Best Way to Replace Windscreen Frame Seal on a 110 NAS R. Kurk Defender Technical Discussions 2 July 10th, 2007 08:30 PM
windscreen frame leaks! Tawayama Defender Technical Discussions 0 October 30th, 2004 01:51 PM
ST windscreen frame used with SW top? Chris Cox Defender Technical Discussions 6 September 28th, 2004 06:21 PM
Water leak Jon D' Defender Technical Discussions 1 September 5th, 2004 08:34 PM
