Water leak - Defender Source
Old September 5th, 2004, 11:23 AM
Jon D'
Jon D'Andrea
'97 D-90, '93 NAS D-110
Water leak
With some moderate to heavy rains, I've been experiencing water accumulation in the center console of my 97 ST with fiberglass top. I fully understand water coming from the doors, but where could the water be coming from to then collect at the center console? Thanks!
Old September 5th, 2004, 08:34 PM
On top of the windshield there are 5 bolts that hold the fiberglass top on, thatís where mine leaks from, I use clear silicone around each bolt to seal it up.
water
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
AC water leak 89classic Defender Technical Discussions 2 June 12th, 2005 01:21 AM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
