Water injection? - Defender Source
Old March 22nd, 2007, 03:32 PM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
Water injection?
Is anyone on here using water injection in a turbo diesel Land Rover? If so what sort and how do you like it? Thanks.
Old March 22nd, 2007, 03:43 PM
WTF? I can't wait to hear this thread.
Old March 22nd, 2007, 03:49 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I have heard of water/alcohol injection on intercoolers
Old March 22nd, 2007, 03:58 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
I've heard of propane...but not water...any more details on this?...I'm curious
Old March 22nd, 2007, 04:01 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Actually, it's done. There is a guy over on pirate named Kermit I think that has been running a water mist into his intake for years. It is supposed to aid in cooling. You might want to search around there to see what you find. Also check some of the euro groups and Yahoo TDi because I think it is more common in Europe. I've never tried it, it scares me.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 22nd, 2007, 04:12 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
It has been done for years on Turbo applications, both gas and diesel. My understanding is that the idea is based on evaperative cooling. Misting small amounts of water into the intake tract cools the intake air temperature, because some of the heat energy is used to evaporate the water. But I'm not expert, and I haven't stayed at a Holiday Inn Express...
~Scott T.
'95 D-90 ST - AA Yellow
Old March 22nd, 2007, 04:25 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
It's not that the water adds more power, but it allows you to really push the limits of other systems that do add power. More importantly, in VERY high compression turbo/supercharged engines it allows for higher boost pressures with a greatly reduced risk of pre-igntion and detonation. Not something used in your normal street vehicles, mostly seen in racing engines.
Old technology too, goes back to the early 1940's at the very least and was a big part of many US fighter aircraft designs, most prominantly in the P-47.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 22nd, 2007, 04:30 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Don't the Subaru WRX STIs come standard with this? That's the last place I heard of it.
"It's not a Jeep"
Old March 22nd, 2007, 04:35 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
yup, a cool feature!
Old March 22nd, 2007, 04:36 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
The WRX and I think that Evo have a jet that sprays onto the Air-Air Intercooler to help reduce temps.
Old March 23rd, 2007, 12:34 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Actually I put the aquamist system on Kermits truck. You read about it on yahoo tdi digest Bucky years ago. It works pretty well but uses a lot of water to keep egts down inthe mountains. A bigger intercooler and larger exhaust seem to function better after trying this route on a couple trucks now.
The system we used was called aquamist. My Saab dealer in KC is a dealer for it if you want to try it out headdamaged.
We use the .6-.8 injector orfices during use.
JP
legend in my own mind
Old March 23rd, 2007, 02:15 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
My race car has an aluminum hard pipe coolant jacket before the air to air intercooler that is piped into the out port on the radiator. Same idea different design. I bet you could even fab one up to fit on a land rover intake. I don't know why you would but it would look cool when you opened the hood.
Old March 23rd, 2007, 01:22 PM
headdamage's Avatar
headdamage
Andrew
I'm going to be putting a 2.5TD 19J into a rover sometime in the next few months and I'm looking into ideas to keep it alive longer. Water injection seemed like a good idea for pushing it over mountain passes and such. I'm also looking into an intercooler. Thanks for the input
Old March 23rd, 2007, 05:50 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I have some leftover 300tdi intercoolers around if you want to do some trading.
JP
water
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Water Pump Help!!! Dfndr90 Defender Technical Discussions 14 May 3rd, 2005 11:51 AM
Water leak Jon D' Defender Technical Discussions 1 September 5th, 2004 08:34 PM
