Water Build-Up - Door Tops - Defender Source
Old May 24th, 2009, 07:37 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Any one on forum have ideas on how to prevent water build-up within door tops?
Weldon
Old May 24th, 2009, 07:57 PM
Clean the drains.
Old May 25th, 2009, 10:54 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Ron, where's this drain located, how do I get to it and where does it lead to?
Weldon
Old May 26th, 2009, 09:35 AM
oldgreentrucks's Avatar
oldgreentrucks
Jim Pace
Located in the lower portion of the window track. Recall one front and one rear. Blow out periodically with air pressure. I think it drains onto the door and out over the side if all gaskets are in place.
Jim
door, door tops, water
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Water leak Jon D' Defender Technical Discussions 1 September 5th, 2004 08:34 PM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
