Washing Machine Sound - Defender Source
Old December 2nd, 2008, 01:16 PM
bjf's Avatar
bjf
barry f
94 ST #395
Why does my engine sound like a washing machine on cold wet mornings?
Old December 2nd, 2008, 02:36 PM
CDeWan
Clay DeWan
5.3L beastie
Belts are loose possibly and are slipping on the pulleys from the morning dew?
Old December 2nd, 2008, 02:44 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I'm thinking it is just the sound of the fan. When it gets real cold out the viscous couplings in engine driven fans usually tighten up and run the fan for a few minutes at first. It used to happen in my blazer, and it happens in the LR3's too.
Old December 2nd, 2008, 04:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
it is usually for more than 15 minutes. wonder if it is my belts. i have had the truck a year and have never done anything to the belts
Old December 2nd, 2008, 05:42 PM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
is it under the dash? could be coolant needs bleeding.
...you'll feel better in a couple of days.
Old December 2nd, 2008, 05:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
no it is under the hood for sure
Old December 2nd, 2008, 06:59 PM
CDeWan
Clay DeWan
5.3L beastie
I would hate to think it is the harmonic balance (crank pully) wobbling around a bit. or.....could be a bearing on one of the tensioners. silly question, but have you popped the hood to see where the sound is eminating from?
Old December 2nd, 2008, 07:13 PM
bjf's Avatar
bjf
barry f
94 ST #395
Popping the hood would be a good idea. Can this be something that is bad to drive with?
Old December 2nd, 2008, 07:31 PM
Grover's Avatar
Grover
Thumbs up
Depending on what is the cause, yes. Check the tension in all the belts. Also, check them for cracks. If they seem worn, replace them. Also, with a pair of stethoscopes, you can narrow in on the location of the "sound"
Good Luck!
Cheers...
Old December 2nd, 2008, 07:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
Can I change ethem myself and is it cheap to do?
Old December 2nd, 2008, 08:29 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I would have to problem doing it, it depends how handy you are (and if you've never done any belt on any "older" truck, then how prepared you are/how much you read about it).
Cheap? Well.... nothing seems cheap to me anymore, but <$70 seems in order for all of them(http://www.roverparts.com/Parts/9229.cfm).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 2nd, 2008, 11:14 PM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks I will check them out and see what is going on.
Old December 3rd, 2008, 12:44 AM
CDeWan
Clay DeWan
5.3L beastie
Barry, Welcome to the world of auto mechanics 101. It is like owning a home you just have to get in there and play around. If you F it up badly then it is time to call a professional. if you follow the sames steps in reverse order when putting something back together when you tour apart then you are golden. In leiu of a stethescope you can you a piece of vacuum or heater tubing to check to isolate the noise. Put one end to your ear and the other you can probe around the engine bay.
Sooner you address the problem or find out what it is, the better and we are here to help. Some of us range from backyard mechanics (me I am going on 22 years under the hood of cars) to master technicians who's knowledge set are abyssal.
Just remember to open the hood when it happens and look and listen.
Old November 25th, 2010, 09:57 AM
Did you ever come to a conclusion?
ac
does this sound like a rover V8 rover4x4 Misc. Chit-Chat 4 January 5th, 2006 06:24 PM
Sound Dampening Material kellymoe Misc. Chit-Chat 1 March 13th, 2005 01:34 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
