WASHER Fluid Pump? - Defender Source
Old December 17th, 2010, 08:45 PM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
WASHER Fluid Pump?
Today I went to squirt the wiper fluid for all the salt build up on the windows.............NOTHING.
I have had the nozzles frozen shut before - but when that happened in the past I could always hear the motor trying to squirt the fluid (and once I thawed the nozzles it worked fine). But today it was complete silence.
So I have not had time to look into this yet. But...........
1) Does this wiper fluid motor work off a separate fuse I should check?
2) Am I going to be looking at replacing a motor / pump?
I guess for now I will be squirting water out of a bottle that I hold out the window when I want to get salt off the window - not the biggest inconvenience when you are talking about a D90
Flaggg
Old December 17th, 2010, 08:49 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I don't know about the fuse. I usually throw 12v at things and work backwards. That will tell you real quick if it is bad or not. I'll check my book in the morning.
And hay
And I love you too
Old December 17th, 2010, 09:37 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Swap the front and rear pump wiring and see if you get a new result.
Old December 18th, 2010, 07:29 AM
Flagg's Avatar
Flagg
Flagg
I am so clueless about engines. This Defender is causing me to learn more and more. There are two pumps - a "front and rear". Are they obvious when you pop the hood...........
Flagg
Old December 18th, 2010, 09:28 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
On my D110 there is blue hose going to the back nozzle and clear hose going to the front nozzle.
Old December 18th, 2010, 12:17 PM
Flagg's Avatar
Flagg
Flagg
OH......FRONT and REAR.
My D90 has no rear wiper or washer (soft top). I am surprised the 110 has this luxury option of a rear wiper and washer
So I should pop the hood, see where the hose goes, and I probably find the pump it sounds like.........
Flagg
Old December 18th, 2010, 01:56 PM
ajh
Andrew J. Hutton
It's attached to the fluid reservoir. You can just apply 12V to the contacts and see if it works. If it doesn't you can get generic Trico Superpumps that fit in-line to take over if you can't get a stock replacement quickly.
Old June 19th, 2011, 02:07 PM
Flagg's Avatar
Flagg
Flagg
Ajh,
I am back on this wiper motor thing.
So clarify - the motor is 'attached' to the reservoir (it does look like it is half in there)? So this means to replace the windshield fluid motor with a stock part I am going to have to replace the entire reservoir??
This is hard to believe - but I guess just a 'land rover' thing.......
Any idea how much that reservoir/pump is going to cost. I think I will be calling Rover's North tomorrow and see what they say.........
Thanks for any thoughts,
Flagg
Old June 19th, 2011, 02:44 PM
bjf's Avatar
bjf
barry f
94 ST #395
I just replaced my washer motor. Super easy. Funny thing Was my reservoir was full so when I took the motor off the fluid dumped out all over the place.
You just pull it off the reservoir to do the replacement.
Old June 22nd, 2011, 11:08 AM
2411D90's Avatar
2411D90
Bob Vogler
1995 D90 Fastback ST (Beluga Black)
I bought a replacement motor from Atlantic British, and replacing the old pump is probably the easiest job you will ever have on your Rover. Here's what you're looking for:
http://www.roverparts.com/Parts/ADU6693LG.cfm
