Washer bottle on a '97 - Defender Source
Old September 19th, 2005, 05:59 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Ok, cant believe I have to ask this but both Tony and I looked all over the damn place and cant find the washer bottle on the '97. Where are they hiding it?
On a side note, the truck didnt come with the manual, anyone have the manual for a '97 in PDF?
Chris von C
[/size]
Old September 19th, 2005, 07:06 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
If I remember correct it was pretty easy to find on my 97.
Here are a few pictures
http://www.expeditionexchange.com/D9...l/DCP_1375.jpg
http://www.expeditionexchange.com/D9...l/DCP_1382.jpg
Old September 19th, 2005, 07:47 PM
I rated this thread in case the question is ever asked again and it deffinitly needs to be added to the FAQ!
Old September 19th, 2005, 08:04 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
As per your request
http://www.indigoprime.com/landrover...p%20Manual.pdf
I just realized you probably meant owner's manual, not the workshop manual. You'll end up needing this soon anyway.
Old September 19th, 2005, 08:46 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Well, that explains why I can find it, it's not there at all.
Anyone have one sitting around? I would try to reuse the one from my 90 but it was where what-ever that white box on the left side is and is about the size of a tennis ball now.
Chris von C
[/size]
Old September 19th, 2005, 08:58 PM
hmm, could it have been possibly relocated? IIRC the hose should come through the firewall on the drivers next to the break booster. If it's not there I would pull the little pannel out to the lower right of the steering wheel, you may have to move part of the AC to get to it but the wiper pump is right back there, it's the pannel with the dimmer switch for the dash lights.
Old September 19th, 2005, 09:17 PM
chrisvonc's Avatar
chrisvonc
Chris von C
I looked everywhere.. inside, put, in the back. if its there I cant find it but its not where its supposed to be according to those pics.
Chris von C
[/size]
Old September 19th, 2005, 09:26 PM
maybe it's in the subwofer box
Old September 19th, 2005, 09:32 PM
chrisvonc's Avatar
chrisvonc
Chris von C
I looked, no fill hole in there if its under there.
btw, the sound system does sound good, if you get a good radio station.
Desnt really matter as I would rather use that box as a storage box so all that bling sound stuff will be getting pulled out
Chris von C
[/size]
Old September 19th, 2005, 09:41 PM
sheki's Avatar
sheki
David Shechter
FYI, that white box is your computer, I wouldn't mess with it.
Old September 20th, 2005, 06:34 PM
ronward's Avatar
ronward
Redsrover
None - sadly
CVC, I removed my washer battle in order to install the Mantec snorkel. I'll see if I still have it around here someplace...
Anything is possible, with the right tools...
Old September 20th, 2005, 06:43 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Ron that would be killer, thanks.
Chris von C
[/size]
Old September 23rd, 2005, 09:44 AM
ronward's Avatar
ronward
Redsrover
None - sadly
Found it.
Old September 23rd, 2005, 09:55 AM
chrisvonc's Avatar
chrisvonc
Chris von C
Hi Ron, groovy, let me shoot you a PM.
Chris von C
[/size]
Old September 26th, 2005, 09:40 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Check your PM CVC.
D90 washer bottle Roverdoc Wanted 1 November 21st, 2009 02:55 PM
d90 washer bottle Gore Ranger Wanted 0 May 16th, 2009 08:32 PM
Washer bottle bracket please JimC Wanted 0 May 4th, 2007 10:24 AM
Washer bottle for a '97 SW chrisvonc Wanted 0 September 19th, 2005 09:27 PM
Are my 97 washer nozzles heated? P1CR Defender Technical Discussions 2 December 17th, 2003 11:54 AM
