was there a conclusion on the electric v mechanical fan issue? - Page 2 - Defender Source
Old April 17th, 2015, 02:40 AM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Do you really even need the shroud?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old April 17th, 2015, 07:07 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I was thinking that but there is a good size gap between the mechanical fan and the radiator.
Old April 17th, 2015, 09:10 AM
Naplm00
Matthew
The Taurus fan flows about the same CFM as my Zirgo. My fan will only run in bumper to bumper traffic on 90+ degree day. When it does its only for a bout 5 min at a time.
Old April 17th, 2015, 09:53 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks for the info.
My guess is once everything is hooked up that the fan will barely run - but will be there when it is needed.
Old April 17th, 2015, 10:28 AM
On a TDI, 10 to 20 seconds at a time.
You need a shroud. Without a shroud, you are losing most of a fan's flow.
Old April 17th, 2015, 11:36 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by Red90 View Post
On a TDI, 10 to 20 seconds at a time. You need a shroud. Without a shroud, you are losing most of a fan's flow.
Thanks again Red - I will just move ahead with the electric setup. Too many small things on my build so I have been a scatter brain.
Old April 17th, 2015, 03:32 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi chaps, what about the intercooler?
Even on idle the mech fan is drawing air across the intercooler which will be lowering the temp of the air charge.
something to think about..
regards all
Gren
Old April 17th, 2015, 06:43 PM
Originally Posted by Gren_T View Post
Hi chaps, what about the intercooler? Even on idle the mech fan is drawing air across the intercooler which will be lowering the temp of the air charge. something to think about.. regards all Gren
That's interesting ... But is any power gain greater than the additional load on the alternator ( from running the fan ) and hence drain on the engine? If it is you have invented a perpetual motion machine and I'll need you to sign this licensing agreement. :-)
Realized I misread gren's comment. Thought he said electric fan.
Old April 17th, 2015, 09:04 PM
The stock 200 shroud restricts flow through the intercooler.
fan
Electric Cooling Fan 97 info needed. WHITE RHINO Defender Technical Discussions 8 January 8th, 2012 02:11 PM
Possible mechanical fan option... Hans Misc. Chit-Chat 9 October 19th, 2009 01:33 AM
I'm making a custom fiberglass electric fan shroud for D90, anyone interesed? jaherring Defender Technical Discussions 1 November 22nd, 2005 01:06 PM
Twin Electric fan kit for V8 D90 kiphartzell Wanted 2 March 17th, 2005 01:06 PM
Did 1995 SW D90s come with an electric fan? arbik Defender Technical Discussions 8 March 1st, 2005 01:27 AM
