Had this light come on the other day and don't know what it is for I looked it up and it said its for ABS, low brake fluid, or a parking brake is on but my problem is I don't have ABS or any of those other sensors, so any help will be appreciated
Try jiggling the parking brake lever to see if you can get it to turn off or at least flicker. Typically that means the switch on the brake lever is bad or has a poor connection.
So we are talking about warning light "D" or "E" or both?
"E" looks super easy. Looks like yellow no trace and goes only to the side of the handbrake.
"D" looks like it gets power from the ignition white/ red trace wire and then to the brake check relay (I don't have a clue what or where that is) brake fluid loss, I'm guessing, is at the MC on the Black wire/ white trace?
I don't know if I have one or not I'll have to look it is a 83 defender so it might not
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
