Warn XD 9000i synthetic line capacity - Defender Source
Old September 21st, 2016, 09:15 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Can anyone confirm the length of 3/8 line that this winch will take?
Amsteel website states only 75 feet. Would like a bit more if possible, although I will have an extension on hand.
Regards, Eric.
Old September 22nd, 2016, 08:23 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Regards, Eric.
Hey Eric,
For 3/8" line, you would probably be best served using the winch line manufacturer's recommendation. The XD9000/XD9000i winches had a 2.5" drum diameter, and were not available with 3/8" wire rope from Warn (I believe a 3 or 3.5" drum is the minimum recommended for 3/8" wire rope, if memory serves), so Warn probably doesn't have a spec for 3/8 rope capacity on this winch.
Why not use 5/16", like the original wire rope?
~Scott T.
'95 D-90 ST - AA Yellow
Old September 22nd, 2016, 09:57 AM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Thanks Scott. Reason for thinking 3/8 is breaking strength of about 17000 v:s 12000 for 5/16.
Could be significant if dragging another vehicle out of somewhere, with the possibility of a double line pull. However, 5/16 would give me 100'. So anyone else using it?
Eric.
Old September 22nd, 2016, 10:00 AM
Naplm00
M
I think that masterpull has some 5/16 with a 3/8 spec breaking strength? Called masterpull pro or something similar
Old September 22nd, 2016, 10:08 AM
LR Max
Thomason, Max
1973 Series 3 109
FYI, I've been running 5/16" on my Warn M12k for almost 15 years now. Its been strong enough.
Stick with 5/16" and get 100ft. Good to go.
Also, check out southeast overland for synthetic. Good guys and you can get extras if desired. Like heat guards and whatnot.
Old September 22nd, 2016, 11:41 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Eric.
I'm pretty sure that significantly exceeds the rating for the original 5/16 wire rope. So I would suspect that if Warn's Engineers/Lawyers let the winch leave the factory with line with a lower breaking strength, you should be fine.
I'd have to do some research to find the supporting facts, but I'm almost certain that pulling through a snatch block (double lining) DOES NOT put twice the load on the cable, as logic would seem to dictate.
My understanding is that in the end, the winch can only generate 9000 lbs of tension, or pulling force, in the cable. The anchor point for the snatch block will see roughly twice the loading however, and your vehicle (if the line runs back to it) will see twice the pulling force..
Need to brush up on my physics I guess, amazing how much you forget over time..
~Scott T.
Old September 22nd, 2016, 05:32 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I have an Xd900i with 150ft on it. I need to trim it down a lot as I have to pull like hell while powering out to get the first couple feet out.
Jimmy Buffett
Old September 22nd, 2016, 06:31 PM
I had 100' on my Husky 10. I cut it down to 60' and made a 40' extension.
It helped a lot.
Old September 22nd, 2016, 11:44 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Very spendy, but interesting.
Superline Winch Lines | Southeast Overland
Not going to be spending that kind of dosh (except in my dreams).
Thanks for all your opinions and assistance. Going to do a bit more research.
Eric.
90, ac, d 90
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 08:38 AM
Warn 9000i winch Abrooks For Sale - Parts 7 September 14th, 2015 08:54 AM
Warn Synthetic Rope Fairlead Z.G For Sale - Parts 2 September 16th, 2013 01:33 PM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 08:03 AM
Doh! ARB 9000i Mounting question dnewman9 Defender Technical Discussions 14 February 5th, 2004 12:11 PM
