Warn wiring - Defender Source
Old September 17th, 2006, 05:41 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Warn wiring
I have no power out on my M10000 -- can't find a wiring diagram for it that actually tells me which 2 of the 4 solenoids power out ("in" is working fine). Anyone have any ideas?
Thanks!
Tony
Old September 17th, 2006, 06:18 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Try www.warnserviceparts.com for parts and information. The solenoids for some of the older control boxes are NLA from Warn but replacements can still be found from Cole-Hersee. I used P/N CH24021 on the last winch I fixed.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old September 17th, 2006, 06:39 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks, Rob -- got the solenoids ($14 ea. from Lee Transport) -- direct match for at least the 10K and 12K. I'll call Warn in the morning to see if they can help, though I can't find a schematic for the solenoid pack on their website.
Old September 18th, 2006, 11:05 AM
Abrooks's Avatar
Abrooks
Tony Brooks
In the interest of closing this thread if anyone else has this issue: this was for an M10000, but should, according to Warn, apply for the M12000. I haven't tested this yet as I'm at work, but if you follow the wiring harness from the remote, there will be a green wire and a black wire, each of which is attached to a solenoid. The Green wire is attached to Power in, the black to Power out. The 2 solenoids for each function (in or out) are located kitty-corner from each other. So, in my case (again, no power out), I will replace the solenoid with the black wire attached and the one kitty corner from it.
Hope this helps someone at some point.
Tony
wiring
Warn winch wiring diagram TwisteD90 Defender Technical Discussions 4 December 27th, 2006 12:32 PM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Husky 10 with Warn Remote?? priest944 Defender Technical Discussions 7 March 31st, 2005 07:56 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
