Warn Winch Problem - Defender Source
Old March 21st, 2010, 08:27 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Warn Winch Problem
my dad installed a brand new warn M8000 winch on his truck recently. He also moved the control box under the hood. After hooking everything up, we installed a plasma rope on it with no problems. It worked great. Several weeks later which was today, he went to use the winch for the first time and it is not working. When you press the in or out button, the solenoids just buzz and click... What gives? it worked when it was installed. Any Ideas what to check? Everything was tight and looked ok....
Legend in My Own Mind.
Old March 21st, 2010, 08:42 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I know you did this, but make sure the drum is engaged. Also try releasing the drum and pulling a little rope out and reengage the drum.
Old March 21st, 2010, 08:55 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I tried that. Actually pulled line out, then went to use it and nothing. we had to spool it in by hand after not getting it to work
Old March 22nd, 2010, 12:08 AM
Make sure your connections are really sound. Also, could be a bad solinoid out of the box.
Old March 22nd, 2010, 08:35 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I will check again and try to test the solenoids if I can figure out how the thing works...
Old March 22nd, 2010, 10:01 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
sounds like a poor battery as low voltage will cause the solonoids to buzz as there is not enough power to hold them on. also check the earth has not become loose or corroded.
Old March 31st, 2010, 08:42 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Fixed it today.. Brand New Winch with a bad solenoid.... Go Figure. Warn Sent me all new ones to switch out.
winch
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
Power Tanks and warn winch TDI Guy Misc. Chit-Chat 10 April 29th, 2005 12:57 AM
Sitting Level - OME & ARB Bull Bar w/ Warn Winch TurkD90 Defender Technical Discussions 23 January 5th, 2005 10:44 AM
warn winch rover4x4 Defender Technical Discussions 3 December 19th, 2004 09:20 PM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
