warn winch - Defender Source
Old December 19th, 2004, 06:23 PM
warn winch
have a 2500 Warn that when put under load it wont spool in under load. the operator was drunk and tryin to pull palets apart for a fire when it crapped out. any thoughts? it will spool in and out but when a load is put on it it was a poppin clickin noise? we are takin it apart now so any thoughts are welcome.
Old December 19th, 2004, 06:45 PM
Maybe a burnt out contact? It may also do that if it doesn't get enough power. And Phil, you know better then to use a winch when drinking.
Old December 19th, 2004, 09:05 PM
when we took it off the mount there was a screw missing from one of the "bars" that holds the sides together. the current hypothesis is that when it got ina bind the body of the winch would flex not letting gears mesh well. will get a screw tomorrow and see what happens. its a 2500lb warn on a aYamaha big bear. its quite a beast.
o yeah could you elaborate on the contact thing?
Old December 19th, 2004, 09:20 PM
The electrical contacts that switch the power on and off, they don't go very often but it was just a guess. But if it has been under water then that increases the chance of burning or corroding the contacts.
winch
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
Power Tanks and warn winch TDI Guy Misc. Chit-Chat 10 April 29th, 2005 12:57 AM
Sitting Level - OME & ARB Bull Bar w/ Warn Winch TurkD90 Defender Technical Discussions 23 January 5th, 2005 10:44 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
