Warn 8274 question - Page 2 - Defender Source
Old November 17th, 2009, 11:13 AM
Thanks for the advise guys. I guess I'll crack her open and see how she looks inside. I have one too many projects and no bumper to use it on, so not sure how quickly I'll get to it. But will at least prepare.
I can't tell from all these threads on it, but if I just want to crack it open for a peek at the condition (or lack of) oil and do an oil change before running it, can I just remove the 3 allen screws and separate the casing without any further disassembly?
BTW, for anyone looking for one of these, I see there is one for sale for $700 in CA right now. Guy says one year old and used 4 times!
http://www.pirate4x4.com/forum/showt...ight=warn+8274
Old November 17th, 2009, 11:33 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Yep, just those 3 big allen screws. It takes 6 oz. of non detergent 30 weight motor oil. I always added just a little bit more than that. When you crack it open you will see why it is wise to run these winches once a month. If not done the top end dries out.
Old November 17th, 2009, 11:41 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I would have to double check which link or links mention it, but while you have the case off i have read that would be a good time to add a drain and or fill plug. A vague 2cents but something to be aware of.
Old November 17th, 2009, 11:58 AM
Yes if I go down the rebuild route I'll see if I can add a drain plug. Someone already added a filler plug.
Depending on what she looks like inside, and how she operates on the bench, I may not rebuild it right now.
Old November 27th, 2009, 10:16 PM
Since I've already hijacked this thread and it's on topic, when I cracked mine open it had been low to empty of oil with water in it and the gears were rusting so I decided it needed a full rebuild. It looks like the main gear sat in water at the bottom and is rather badly corroded. Am I looking for trouble putting this back in?
http://gallery.lhsw.com/warn_8274_main_gear_damage
A new replacement is a bit pricey. I'm worried these damaged teeth will have their ends disintegrate and then chew up the other gears.
charles
Old November 27th, 2009, 10:54 PM
charles
Cheap ends up not being cheap ?
Old November 28th, 2009, 04:41 AM
I would run it as is. Of course, that advice is not of very much use to anyone.
Old November 28th, 2009, 08:30 AM
Hehe, this didn't start cheap if you consider I could have bought a brand new 9k superwinch for less. In for penny in for a pound I guess. I see a good looking used main gear on eBay.
Old October 17th, 2010, 10:28 PM
airbornrover
William Skidmore
SIII 109 SW
Does anyone know if the 8274 and bellview are inter compatible for parts?
Old October 18th, 2010, 02:50 PM
outfield
Steve
1995 D-90 SW #351
Hi William,
No, the 8274 and Belview winch parts are not interchangable.
Old October 18th, 2010, 03:16 PM
Depends on what parts. I have seen bellviews updated to 8274 motors.
Old October 18th, 2010, 04:31 PM
airbornrover
William Skidmore
SIII 109 SW
would that be including some fabbing? reason im asking is that i found an awesome deal on a bellview for 200 (to good?). wanted to know before i pull the trigger, other wise ill just go for the 8274
Old October 18th, 2010, 04:42 PM
I don't know. $200 seems fair if it is complete and works.
Old October 19th, 2010, 02:43 PM
outfield
Steve
1995 D-90 SW #351
If you need parts for a Bellview winch contact 4 Wheel Drive Center in St. Louis Park, MN. 952-927-8811 or 800-328-4445. John has rebuilt motors and some of the popular parts manufactured for resale.
Old October 19th, 2010, 03:46 PM
airbornrover
William Skidmore
SIII 109 SW
Thanks for the heads up on the parts for the bellview.
Warn 8274 brake pad relacement? Hammertime Defender Technical Discussions 4 September 8th, 2009 10:05 PM
Rockware bumper Warn 8274 combo KevinNY For Sale - Parts 15 July 23rd, 2009 10:34 PM
Winch Bumper For Warn 8274 Hammertime Wanted 3 January 29th, 2009 07:53 PM
Relocating Warn 8274 solenoid pack? KevinNY Defender Technical Discussions 19 April 2nd, 2008 08:42 PM
Bumper for Warn 8274 winch? on a 90 Hammertime Defender Technical Discussions 7 April 1st, 2008 04:18 PM
