Wanting to install a subwoofer - Defender Source
Old January 14th, 2004, 12:11 AM
Matt Klapmust's Avatar
Matt Klapmust
Matthew Klapmust
'94 D90 ST
I was thinking of installing a self-powered Bazooka, but wanted to see if anyone had suggestions on improving the stereo system. The head unit is a Kenwood that I hope to have installed as well.
Old January 14th, 2004, 12:28 AM
Rick Carlisle's Avatar
Rick Carlisle
Rick Carlisle
1997 Alpine White D-90 SW
Matt,
I just upgraded my system. And I looked at installing two Bazookas but found, through my research, that they are not the greatest subwoffer. So I bought two JL Audio 8" subs, had fiberglass enclosures made for them and mounted them between the jumps seats in the rear, one per side. That, coupled with 4 MB Quartz speakers, a JL Audio 300 watt/4 channel amp, a JL Audio 250 watt/mono amp and an Alpine FM/CD/MP3 player and an Alpine 6 disc changer, and I am happy.
I drive this truck a lot every day. I've got to have my music or I would go nuts.
Rick
Old January 14th, 2004, 12:47 AM
Matt Klapmust
Matthew Klapmust
'94 D90 ST
That sounds pretty cool. Where do you have the amps placed? I am guessing they are mounted on the enclosures themsleves?
Old January 14th, 2004, 01:53 AM
scot's Avatar
scot
Scot Yount
95 Coniston Green D-90 SW
I have been told (this sounds risky) that cutting a hole in the front of the passenger seatbox is a great way to mount a subwoofer....plus you could actually hear it....
Wherever I go...there I am.
Old January 14th, 2004, 08:34 AM
Rick Carlisle
Rick Carlisle
I have the 4 channel amp mounted under the passenger seat (as high as possible) and the mono amp mounted on top of the cd changer below where the storage area used to be in the center console. I saw "used to be" since the previous owner has butchered the console by removing the storage area completely and had a boxed 10" subwoofer in place of the storage area. I still need to create a shallow storage tray and clean up the large circular cut he/she had made at the rear of the console. But I have plans for that, just haven't done it as yet.
I have no trouble hearing my subs. If there was a bit more "sound absorption" material in these trucks, I would say the sound would be absolutely awesome. But I'm not complaining.
Old January 14th, 2004, 09:26 AM
If you want a good self powered sub infinity makes a 200 watt unit that is made to fit under a normal seat. I had a Bazooka and it was ok. It did not hit the real lows (below 100 Hz) and if it got a little wet it did some very interesting things.
Old January 14th, 2004, 06:01 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
Rick-
Any pics of the installation? I'd like to see what you came up with.
Thanks.
Old January 14th, 2004, 09:36 PM
Rick Carlisle
Rick Carlisle
Torrence,
I will have to take some and post them. I switched to an iMac and feel like I have never used a computer before so give me time and I will figure it out. I can't even figure out how to reduce a photo to 100x100 pixels for my avatar!
Rick
Old January 14th, 2004, 10:03 PM
mpodgorski's Avatar
mpodgorski
martin
'94 D90 ST Arles
rick
are you running panter 10.2.3? Anyway in appleworks, if you paste your pic from the program preview, you can decrease the size of your photo to meet the size you need
Subwoofer install instruction ? jorge Defender Technical Discussions 1 February 11th, 2009 07:56 PM
4.6 install will it work ron Defender Technical Discussions 16 February 7th, 2008 10:16 AM
Subwoofer install under passenger seat with speakers facing upwards seattlejanzen Defender Technical Discussions 12 February 22nd, 2007 12:17 PM
Tailgate Subwoofer Box and Speaker boshea For Sale - Parts 9 December 21st, 2005 11:47 AM
Stealth Subwoofer Install gtg067i Defender Technical Discussions 4 August 7th, 2005 08:53 AM
