Wading plug and drain hole? - Defender Source
Old April 6th, 2010, 01:31 PM
T.U.
Pete
94 D90
Question Wading plug and drain hole?
O.K., I'm an idiot.
I scoured the bell housing and can't find the wading plug or drain hole.
The only thing I can find is at he bottom center of the bell housing, where it bolts up there is a small retangular hole, but there is no way you're putting a bolt in there.
Any help in finding this would be appreciated.
1994 LT 77 tranny
Old April 6th, 2010, 02:36 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
pic? Mine is at the lowest point. It's not actually in the bell housing, but the adapter plate - 1" forward of the joint with the bellhousing. Pictured is a 200tdi/lt77 joint (1992)
Old April 6th, 2010, 02:46 PM
T.U.
Pete
94 D90
Thank you very much for the quick reply, but my set up is different.
No drain hole.
Old April 6th, 2010, 03:39 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
you omly get wading plugs in a diesel
3rd low and BOOT IT
Old April 6th, 2010, 03:48 PM
I think it is on the inspection cover. But I am not 100% sure.
drain
transmission drain and fill rover4x4 Defender Technical Discussions 24 November 16th, 2011 02:31 PM
metal shavings on trans plug - any concerns? WI-ROTTIE Defender Technical Discussions 12 October 2nd, 2010 09:38 AM
Drain Plug Diffs/Xfer Case Grover Defender Technical Discussions 7 November 11th, 2009 11:21 PM
where is drain plug for the swivel housing UpnOver Defender Technical Discussions 10 July 23rd, 2007 03:23 PM
Oil pan drain plug thread Pat Defender Technical Discussions 0 June 23rd, 2006 09:02 AM
