Wading kit on 2.8 - Defender Source
Old August 28th, 2008, 10:16 AM
Wading kit on 2.8
Can anyone tell me what vents on the 2.8 need to have vented lines plumbed into the wading kit manifolds to integrate the engine into the wading kit? It doesn't look like the vents are quite the same as the 300 tdi, and I don't want to miss one.
Also, my clutch bell housing (late model R380) doesn't appear to have a wading hole that accomodates a wading plug. All I see is a crescent shaped hole where the bell housing meets the gear box. Am I missing something?
Old August 29th, 2008, 06:32 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
The vents are all the same as the 300 on every 2.8 I have had. 1 at the bottom of the timing cover and 1 at the bottom of the clutch cover (bellhousing)..unless it is a late model V8 adaption in which case there may not be a spot for one.
Matt Browne
kit
The 2.8 TGV and 300TDI to GM adapters are in stock OBW_Canada The Vendors Loft 5 December 14th, 2006 11:12 PM
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
SG JEK 3 Suspension Kit 97D90 Defender Technical Discussions 7 September 23rd, 2005 10:00 PM
Rovers North 1.5 inch lift kit w/shocks Seriesman For Sale - Parts 1 August 26th, 2005 11:45 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
