Wading in deep mud...what fluids do I need to change? - Defender Source
Old May 3rd, 2013, 04:54 AM
sro
Sam Odio
2008 LR2
I spent some time a few weekends ago in deep mud. Does anyone know what fluids I should change?
Also, I couldn't find a wading plug on the transmission (R380). Am I missing something? This thread makes it seem like they're only on diesels: http://www.defendersource.com/forum/...ad.php?t=24940
Old May 3rd, 2013, 07:28 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I guess it depends on how long you were in the mud and what the conditions were before going in. Your rear axle vent is not much higher up than the mud you were in. The front axle and transmission vents are higher up on the firewall. If you haven't replace your axle fluid might be a good excuse to replace it. If you went in hot and the water was cool you might have sucked in water to the other fluids but if everything was sound you may be OK.
I could be wrong but I think all the R380's have the wading plug hole. It is on the bottom of the bell housing.
Old May 3rd, 2013, 07:57 AM
Just check your fluids, make sure they don't look like chocolate milk. If you didn't change all of them when you bought the truck, now is a great time to do it.
Old May 3rd, 2013, 08:09 AM
87 D110 (Ruby)
Diff fluids = 90wt oil, also swivel ball housing should be checked, this is oil as well, unless someone was running grease before you...then you have a PIA to get all the grease out.
Old May 3rd, 2013, 09:26 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
X2 on the diffs, transmission and t-case. That stuff looks like wet concrete.
Old May 3rd, 2013, 09:33 AM
Definitely clean out the mud ASAP with a hose. Once it dries in odd places, it's very difficult to remove. This includes in the engine bay and between the bulkhead and outriggers and inside the frame.
What Craig said as well - the swivel balls especially. The seal on the swivel ball is only for keeping oil/grease in the ball - there is actually a gaping hole near the top of the seal that will allow water to ingress easily.
Old May 3rd, 2013, 02:15 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Looks like on AT tires with little to no tread. Did momentum only carry you that far?
Old May 3rd, 2013, 04:08 PM
sro
Sam Odio
2008 LR2
Well, it sounds like the general consensus is to check or replace just about everything. I'll start by checking the diffs and replace the fluid in the swivel balls. Before my next long road trip I'll also check the zerks on the u-joints, fluid in the transfer case, and the transmission fluid. ugh...
I cleaned out the mud the next day. I was able to get almost all of the mud off. However there's still mud in the inside of parts of the frame. I ran water through the frame (the best I could) for about 30 minutes but the mud was just too thick. The water ran out of the frame clear, but I could tell there was still mud in there.
Now I know any time the inside of the frame gets wet it's going to take forever to dry. Has anyone else been in this situation? Is there some sort of solvent I can use to break up that mud?
Old May 3rd, 2013, 04:13 PM
Just check. If seals are all good, everything will be fine. That picture is every trip, all day long around here and much deeper. I do have extended breathers though and anyone that wades should put them in.
Old May 3rd, 2013, 04:22 PM
Best way to break up mud is with a hammer
Old May 3rd, 2013, 06:12 PM
sro
Sam Odio
2008 LR2
I would except it's inside the frame...
Old May 3rd, 2013, 09:14 PM
If you haven't just go ahead an replace the fluid in the R380 with some MTL, everything else is probably low and needed to be changed anyways. I've spent a lot of time in the deep NC clay that we have in the piedmont, Ive always been impressed with Rover wheel bearing seals. I run wet hubs and have never had issues.
Old May 3rd, 2013, 09:19 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Ditto what John said about your breathers. If you like to play in mud/water, then get extended breathers. Some folks even run them inside their snorkel up to the cap--I just ran mine to above the engine between the bulkhead and engine.
If you don't have extended breathers, then personally, I would at a minimum check all my fluids. I would take my fill plugs out and dip something into the fluid to check. Personally if my finger doesn't reach, I top them off anyways, but first I will dip something down to also judge how much they leak out. I don't like leaks--that typically means something has a better change of getting sucked in as well. I keep all my fluids running clean and clear and change them every year or so no matter what. You can usually tell when you have sucked contaminants into the fluids. If there is any doubt, or they are generally dirty (or don't smell right some cases) then I change them.
Old May 3rd, 2013, 09:55 PM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
That's the first thing I noticed...
Old May 3rd, 2013, 10:02 PM
sro
Sam Odio
2008 LR2
Actually already changed all the fluids 1-4,000 miles ago, so I'd prefer not to change them again.
I will check them for mud though.
Old May 4th, 2013, 05:54 AM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Looks like you wer pushing mud if front of you. If you did not blank off the rad (and AC condenser) make sure it is thorougly hosed through. You may have to go from inside the engine bay, and pull the grill. That mud will have set up hard.
Old May 4th, 2013, 07:03 AM
Did you have the CDl locked?
Old May 4th, 2013, 07:29 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I douse my frame with wd40. It allows mud and salt to wash off with water without power washing it. I also spake the inside of the frame with it as well. Helps keep the moister off/out.
Clay
Old May 4th, 2013, 06:29 PM
sro
Sam Odio
2008 LR2
Good thing I checked the diffs. Front diff oil is the same color as the mud pit. Now I'm draining the swivel balls too (they're also dark). That oil is about 2,000 miles old...
The next thing I need to do is check the transfer case and transmission oil...
Old May 4th, 2013, 09:39 PM
better douche out those swivels
Deep water wading with the NAS clutch cover sro Defender Technical Discussions 3 March 14th, 2013 08:04 AM
How often to change fluids? aaronlam Defender Technical Discussions 7 August 27th, 2012 09:47 AM
4 BFG 255/85/R1 Mud Terrain KM on RR deep dish alloys cdb For Sale - Parts 6 March 18th, 2011 11:41 AM
Deep Water wading Uncle Douglas Misc. Chit-Chat 17 February 25th, 2008 08:50 PM
Defenders eat mud! rustydefender Misc. Chit-Chat 13 February 8th, 2005 06:14 PM
