VW switch for Flex alite fans - Defender Source
Old October 1st, 2011, 03:13 PM
red&yellowrovers's Avatar
red&yellowrovers
Joe Still
95 D90 NAS 3.9l ST AA Yellow #2719
Thanks in advance for not pointing out how little I know about elec.
I have a 95 D90 3.9 with flexalite dual fan set up. The controller died and someone rewired the fans to "igniton on- RUN".
I have purchased the VW temp switch for the tstat housing conversion as the cleanest option for me.
Now for the big laugh, do I assume I switch the black or negative side? Or the hot side?
See preface above.
js
Old October 1st, 2011, 04:27 PM
The Dro
Dro
1988 Ninety
I don't quite understand your question. But, I had the FAL 295 fans with their VSC.
You can buy a new VSC from FAL, that is the best course of action.
You can get the 31165 for $99.
Old October 1st, 2011, 08:07 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
Generally VW switches the positive side of the switch (the fan motor is connected directly to ground). If you give me the part number, I can tell you how they wire it provided the part number is from a model between 85 and 2004 ( I've got a bentley library at my house).
fan, flex, switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
