VSS function - Defender Source
Old February 8th, 2012, 09:55 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
VSS function
Here's what I've done:
Fit a fuel injection set-up from a 94-5 D90 onto a carbbed 89 3.5 OneTen. This car has a cable drive for the speedo and no signal generator.
What function does the VSS serve besides telling the ECU that the vehicle road speed has been exceeded and the ECU starts cutting out injectors? The Rover runs and drives with the current set-up, but it occured to me that I don't know what else the VSS may contribute, and I have a code 68.
What are your thoughts?
Email is
Same place, new dogs.
Old February 8th, 2012, 10:07 PM
It changes the idle mode. Idle control is faster when stopped. As you stop is raises the idle as well. Without the VSS you will have weird intermittent stalling problems when stopping.
Old February 9th, 2012, 06:59 AM
Roverlab
Trevor Griffiths
So if I measure the resistance across a VSS and install a resistor in the harness connetors for the VSS, the ECU will recognise VSS presence, think the car is in idle mode, I just wont have a "speed limiter"?
Email is
Old February 9th, 2012, 08:15 AM
After an LT230 swap on my RRC I had issues with stalling that I attributed to the VSS not being hooked up. It was a mostly off road only vehicle, so I never bothered to fix it. It would stall when coming to a stop.
Old February 9th, 2012, 10:33 AM
Roverlab
Trevor Griffiths
Road going, need to come up with a solution. MAy just have to add a short cable and VSS.
Email is
Old February 9th, 2012, 10:59 AM
Roverlab
Trevor Griffiths
It's an 89 with an LT230 and a cable drive speedo from the t-case. I have a VSS on the bench, a short cable is cheap enough, and the excess of the long cable-if it fits the VSS -probably can be safely routed. Still, wondering if I could just "fake out" the ECU.....
Email is
Old February 9th, 2012, 11:11 AM
No. The VSS sends a pulse signal to the ECU. When the ECU does not get the pulse, it errors out that the VSS is broken. Normally it will then never goes into idle mode. The best solution is to install the VSS.
I just went through this last year converting a truck to EFI and it is very annoying not having the VSS installed.
Old February 9th, 2012, 11:29 AM
Trevor the 94 NAS D90 has a two piece speedo cable setup with the VSS inline so you can use those instead of trying to use the long one.
Originally Posted by pendy
I'm here for the D's
Old February 9th, 2012, 11:39 AM
Yes, but the cable from box to speedo is NLA, as they were only used on NAS 90s, so you need to find a used one. The long cable won't work easily as the connection to the box is different.
The solution I like is to install a VDO speedo...
Old February 9th, 2012, 01:34 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Agree, we just put a 95 D1 eng/trans into an 83 110 and we replaced the speedo with an electronic one since it was a lot easier than messing around trying to hook up the mechanical one in the truck. VSS is the stock Disco one bolted to the T-Case and connected to the ECU. If I remember right we then took an output from the ECU (not the VSS) to drive the speedo. We used a stock LR Speedo that the owner got used but the VDO would have been better (since its programmable) and probably cheaper.
Old February 9th, 2012, 04:46 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Actually when the VSS senses movement it raises the idle. Once the truck comes to a stop it returns to base idle. Without it the truck usually stalls when coming to a stop.
Old February 9th, 2012, 05:51 PM
Roverlab
Trevor Griffiths
Hi James! this is the fuel injection from the engine you sold to Art! We put the engine in his 110 but he wanted to stick with the carbs.
Thanks for all of the input. I have a VSS on the bench so I'll just source some cables and give it a go. I'll et you know how it goes...
Email is
Old February 9th, 2012, 08:16 PM
James Pierce
James Pierce Jr.
Awesome... lets see some pic's. I can't believe he didn't use the EFI...
You will need the VSS for it to function correctly. Either a Disco version with a pulse driven speedo or the one you have of Art's with the two cables and a mechanical speedo.
Is a Disco I VSS compatible with LT95 4-spd? Miller Defender Technical Discussions 14 November 1st, 2012 02:16 PM
Dome Light / '97 Multi Function Unit GYM Defender Technical Discussions 2 March 6th, 2007 05:53 PM
Help with VSS Malfunction Code Seriesman Defender Technical Discussions 8 December 20th, 2005 10:58 PM
OME spring set-up by intended use- used search function lactic Defender Technical Discussions 5 October 14th, 2005 01:22 PM
97 D-90 Vss Help Sirfoss Land Rover Defender Technical Discussions 3 August 9th, 2004 08:11 PM
