VSS - 94 95 VDO speedo thread - Page 2 - Defender Source
Old April 23rd, 2013, 01:55 PM
Originally Posted by Stmpede View Post
Thanks John, I just want to be clear, I can use the YBE100540G with the VDO Gauge and it will give a correct reading?
Yes, I've used that sensor for years. I have not personally used it in parallel with an EFI ECU though as I have a diesel.
Old April 23rd, 2013, 02:34 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Great! This is my solution!
Ok, one more question...what is the YBE100540G? When my Parts Mgr types it in the System says it is not defined for our market, but without the G at the end it is available through LRNA...
Old April 23rd, 2013, 04:23 PM
G is just to say it is a genuine part instead of aftermarket. It is the speed transducer used on all Disco 1s. Junkyard from a dead Disco is the cheapest.
Old April 23rd, 2013, 04:30 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Ok, I just wanted to make sure that I wasn't ordering a different part. Land Rover uses different suffix's when it is a updated part etc. I have never seen G used, so I was concerned what it may mean.
Thanks again for all the help!
Old April 23rd, 2013, 04:36 PM
G is atlantic british's way of telling you that you are buying genuine.
95, speedo
94 that looks like 95 wagon...not mine WeBeCinYa The Flea Market 3 February 16th, 2013 10:21 PM
94 speedo cable Rommel Defender Technical Discussions 2 November 21st, 2012 12:23 PM
VDO Speedo Power and Ground wcampbel@nas.edu Defender Technical Discussions 8 November 26th, 2011 09:14 PM
94 ST AC into a 95 SW leastonce Defender Technical Discussions 8 August 7th, 2010 08:17 AM
Thread hijacking! TwisteD90 Misc. Chit-Chat 19 March 6th, 2004 03:23 PM
