voltage regulator - Defender Source
Old May 4th, 2011, 10:09 AM
maleger
Marc-Andre Leger
voltage regulator
Where is the voltage regulator located in the 1994 NAS D90 ?
I need to replace the regulator that is, I think in the 100A Marelli alternator to rewire for my dual battery setup, but I'm not sure how to proceed. I have an external regulator as well as the battery isolator. I figured out the wiring from the electrical schematics I have, I just need to figure out how to disable the existing regulator !
Old May 4th, 2011, 09:10 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
As I understand it, the regulator is internal to the alternator. The regulator can be replaced on my 60amp; I'm not certain the layout of the 100amp.
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Help with voltage issue Mpigapicha Defender Technical Discussions 3 August 9th, 2010 09:51 AM
air meter voltage adjustment? Rod Hayward Defender Technical Discussions 4 July 24th, 2005 11:24 PM
Alternator and Regulator (Diodes) arbik Defender Technical Discussions 3 April 14th, 2005 05:20 PM
window regulator handle? snuffer Defender Technical Discussions 2 November 21st, 2004 10:22 AM
help - where is my voltage KeithD Defender Technical Discussions 26 November 13th, 2003 04:11 PM
» Defender Registry
110
clb1994
Tree Hugger
easy
Add your Defender
