VNT Turbo kit for 300Tdi.....Worth it? - Defender Source
Old March 8th, 2012, 10:56 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
I'm looking to get a little more torque and low end out of my 300Tdi. I know a few people have installed this kit in the past. I'm just wondering if it's worth the money for the performance gain.
I talked to a local diesel/turbo shop, and they said my turbo is probably in need of a rebuild or replacement anyway. I'm looking at about $700 for a turbo only, or $2200 shipped for a VNT kit with all new hoses, exhaust manifold, etc. So for an extra $1500, are the gains worth the money?
Old March 8th, 2012, 11:59 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Check this thread
http://www.defendersource.com/forum/...ighlight=turbo
Old March 8th, 2012, 12:09 PM
jrose609's Avatar
jrose609
Jason Rose
Originally Posted by Dennis View Post
yes. I saw that thread. I tried emailing Ian with IRB and no response. I've emailed him a few times. Seems like the OP from that thread has had about the same amount of luck.
I've been in contact with David Jackson from M&D in the UK. When I did my conversion, David was helpful and prompt. If I have a problem, I know he will work with me to fix it. Ian probably not so much.
Old March 8th, 2012, 12:31 PM
Naplm00
Matthew
http://bellautoservices.co.uk/
Old March 8th, 2012, 03:03 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Ian is good, but like you've discovered, a PITA to get hold of sometimes... I class him as a mate (eventhough I don't see him that regularly) and he's still hard to get hold of sometimes.
I have one of his VNT turbos on my Td5... makes it much more drivable. no "extra" torque (Well, excluding the ECU remap that is) but just more torque lower down the rev range.
Deffo a good conversion.
Old March 8th, 2012, 10:44 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
The M&D conversion is well worth while. I have not bothered with adjusting the fueling yet but right off it makes the 300tdi more tractable. Useful off-road and also city driving. On a local hill I used to take it in 2nd, now it will hold 3rd.
Kit contains everything you need and fitting straightforwad. A bit fiddly around the alternator due to proximity of piping.
Fit an exhaust pyrometer while you are at it. There is no EGR or blanking plate on the new manifold so you do not want to rip everything out again afterwards.
Old March 8th, 2012, 11:10 PM
What he said!
Old March 8th, 2012, 11:32 PM
jrose609's Avatar
jrose609
Jason Rose
Originally Posted by Naplm00 View Post
Matthew, thanks for the link. Good info.
Jamie, good to know. Maybe next time you get a chance to talk to Ian let him know it's hard to give him money if he doesn't answer.....
Right on. Good to hear the M&D conversion worked well. Did you do the install yourself ? How long did it take you?
Old March 9th, 2012, 05:44 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I love mine
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old March 9th, 2012, 09:15 AM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Any experiences with the Bell turbo? Is it a direct replacement for the stock one?
Old March 10th, 2012, 05:02 PM
jrose609's Avatar
jrose609
Jason Rose
Originally Posted by Hoosier View Post
I love mine
I will let you know in about 2 weeks how mine is. Just ordered a kit from M&D.
Old November 1st, 2012, 12:50 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Considering ordering a kit. Who is the preferred vendor to order from?
Old December 3rd, 2012, 12:56 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My kit will be here on Wednesday. Any hot tips on how to install? How do you guys like it? I have an EGT gauge and sender to install as well. Where do I put the sender?
Old December 3rd, 2012, 01:31 PM
jrose609's Avatar
jrose609
Jason Rose
Follow the instructions and take your time.
I installed the EGT sender in the exhaust manifold. Drilled a hole and tapped it.
The VNT turbo woke my truck up. It's a different beast now. Highly recommended. Not inexpensive, But not s lot more than a standard turbo replacement.
Old December 3rd, 2012, 02:41 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Where did you get it from?
Old December 5th, 2012, 10:58 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Can anyone snap a pic of where you installed the sender (if you have one).
Thanks!
Old December 5th, 2012, 11:04 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Keith @ Rovertracks. I snagged the last kit I believe.
Old December 6th, 2012, 03:13 PM
andy110
Andy Bard
1986 110 CSW
They are available from a few UK suppliers as well:
http://www.allisport.com/index.php?o...id=170&lang=en
http://www.allardturbosport.co.uk/in...ry-200-300-TDI
http://www.ebay.co.uk/itm/300-Tdi-VN...-/170332644467
Old December 31st, 2012, 09:34 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I was about to tap a hole in the manifold today when I realized I may need 1 1/2" of clearance above the new manifold for the EGT Sender which sticks out about the same amount. I was wondering if anyone who has installed the M&D Engineering VNT Kit on their 300tdi could tell me if there is any interference with parts above the manifold? Perhaps you can snap a picture? I plan to pre-assemble the parts just to make sure there isn't a hose or something located right on top of the manifold but pictures would help.
Old January 1st, 2013, 02:11 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Why not just tap a hole/weld a nut, onto the blanking plate where the EGR valve would normally live.
300tdi, kit, tdi
DIY VNT turbo for 300TDI? jaherring Defender Technical Discussions 47 August 15th, 2013 07:26 PM
Turbo factoid Overlander Defender Technical Discussions 2 January 15th, 2011 01:32 AM
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
remote turbo? Rod Hayward Defender Technical Discussions 7 January 11th, 2005 04:16 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
