Viscous Fan Clutch wrenches - Defender Source
Old July 17th, 2015, 05:02 PM
chuckc4
chuck b
Registered User
Anyone near Albany NY, whom I can borrow the two wrenches I need to replace my viscous fan and water pump from?
Chuck
Old July 18th, 2015, 07:54 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
I use a large C wrench & a hammer. Works all the time.
Old July 18th, 2015, 09:20 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
I exhausted all suggested methods and finally removed it as a unit with the water pump, then cut it off. Now, all methods work .
You can borrow the 32/36 mm thin spanner from most auto parts stores if nearby...definitely try the method suggested above first.
Old July 18th, 2015, 09:27 AM
Ray_G's Avatar
Ray_G
Ray Gerber
Worth just buying the wrench in case it ever has to be done again.
Old July 18th, 2015, 10:08 AM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
1 1/4 inch open end and a hammer works well for me every time.
Old July 18th, 2015, 11:09 AM
get the wrenches. 80% of the DIY jobs you do require that fan to come off. That's the first special tool anybody should have.
Mark Kellgren
KM4BOR
Old July 18th, 2015, 11:33 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
If its never been off it can be a real pain and smacking a wrench with a hammer may not get it. Ive used a free rental tool from Pep Boys to hold the viscous clutch while turning the nut.
Once you get it off slap some antiseize on there and the hammer smacking trick will work every time from there on out.
Old July 18th, 2015, 02:08 PM
DBrands's Avatar
DBrands
David Brandson
D90 Truckcab
It's a tight fit for conventional wrenches. I went and bought a slim wrench for bikes. 32mm isn't it? Only cost me $12
Old July 18th, 2015, 02:14 PM
Departing90
Sasha
95 D90
Lmao....
You left out one other method! Using a chisel to turn the nut.
Get the proper tool. punch it in amazon and its 40 or so. Same size nut as many BMWs so the tool is common and cheap. Less than 10 seconds and its off, you dont damage the water pump, your fingers, engine bay or the nut itself. When putting the fan cluch back on make sure tye threads are clean and apply a tiny bit of anti seize so it'll come off without any possible issues in the future.
Old July 18th, 2015, 02:43 PM
rovertrader's Avatar
rovertrader
Dale
That and a hub nut socket/wrench...
Old July 18th, 2015, 03:17 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Originally Posted by Departing90 View Post
Lmao.... You left out one other method! Using a chisel to turn the nut. Get the proper tool. punch it in amazon and its 40 or so. Same size nut as many BMWs so the tool is common and cheap. Less than 10 seconds and its off, you dont damage the water pump, your fingers, engine bay or the nut itself. When putting the fan cluch back on make sure tye threads are clean and apply a tiny bit of anti seize so it'll come off without any possible issues in the future.
36 for 4.0 GEMS IIRC. 180k and it was frozen solid. As I stated, I tried every method...including your chisel. And I whacked that sucker without regard for the WP...
Old July 18th, 2015, 06:10 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
It's a left hand thread, sometimes!
Old July 18th, 2015, 07:37 PM
chuckc4
chuck b
Registered User
Seems to me this is what happens when you bang on a C wrench.....
Old July 18th, 2015, 09:08 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
I love wenches....
Attributed to Shayne...
Old July 18th, 2015, 09:23 PM
BlackField's Avatar
BlackField
Oscar
D110
is there a photo of these spanners? are we talking about just a big open end wrench or is this thing special in some way?
I plan on pulling my VC and fan tomorrow.
Old July 18th, 2015, 09:36 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
They're also skinny oscar to allow you to slip in from the top. They're also long handled spanners.
http://pages.ebay.com/motors/link/?n...00618&alt=web*
I can measure how thick my fan spanner is in a few days or so
Old July 18th, 2015, 10:09 PM
DBrands's Avatar
DBrands
David Brandson
D90 Truckcab
http://www.mec.ca/product/5010-729/f...10/50002+50530
28.5 canadian loonies for the double whammy. 32 for the diesel fans, and 36 for the v8?
As far as thickness, about 3/16" as I recall. Away from home so can't measure mine.
Old July 18th, 2015, 10:31 PM
chuckc4
chuck b
Registered User
Yes, they ar skinny. And, they don't look like they are worth $100 US for the set from a certain rover parts supplier. they look like they are worth $10
Old July 18th, 2015, 11:06 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Amazon has a craftsman set with the 36mm for $22
Old July 18th, 2015, 11:19 PM
rankar's Avatar
rankar
I bought the set I posted that's on ebay for $100 for $49 from Amazon a few years ago.
Great having the right tool.
clutch, fan, fan clutch
3.9L V8 viscous fan clutch removal nathanwind Defender Technical Discussions 47 April 18th, 2015 05:31 PM
200Tdi fan with viscous clutch transientmechanic For Sale - Parts 1 October 23rd, 2013 07:55 PM
Viscous Fan Clutch ERR3443 with Fan ERR3439 JohnC For Sale - Parts 1 September 22nd, 2013 12:34 PM
Viscous Fan Clutch NAPA part # Campbell Defender Technical Discussions 4 January 29th, 2011 09:53 AM
Size of fan bolts on viscous fan clutch imeek Defender Technical Discussions 4 September 26th, 2009 03:12 PM
