Viscous Fan Clutch wrenches - Page 2 - Defender Source
Old July 19th, 2015, 12:12 AM
huibae's Avatar
huibae
Harold Lee
Jon Snow Badge 1122
Originally Posted by SMac View Post
I exhausted all suggested methods and finally removed it as a unit with the water pump, then cut it off. Now, all methods work .
You can borrow the 32/36 mm thin spanner from most auto parts stores if nearby...definitely try the method suggested above first.
SMac,
So Im in the process of doing this. Tried everything to get the clutch off but no win. So I started to take the water pump out as I was going to replace it anyway.
I removed all the bolts except for the one at 6 O'clock because the pulley prevents it from sliding out all the way. I cant remove the pump - wont budge.
Any hints?
H
Old July 19th, 2015, 12:34 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Harold, There are many certified and/or old time Rover techs here, one will probably chime in with the gospel truth... If your pump wont budge at all, you may have simply missed a bolt. I cant quite remember how many there are, but some on the underside and side of the pump are bears to get to. I removed my upper fan shroud and alternator for clearance, and I remember wishing I would have removed the lower fan shroud as well.
Edit...so feeling around the WP, I believe there are 9 total bolts.
Old July 19th, 2015, 12:59 AM
Also sometimes an RTV seal is a mutha to break.
Old July 19th, 2015, 02:41 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Exactly. Also, go to the land rover forum website, go to the d2 section and do a search for fan removal. I believe the members came up with all sorts of ways to remove the fan.
Old July 19th, 2015, 06:22 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
We have them pretty cheap, pm me if you need one for a little less, they are good to have.
http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
Old July 19th, 2015, 08:04 AM
chuckc4
chuck b
Registered User
Thanks Zack, that is a reasonable price! Will order one up Monday am.
Old July 19th, 2015, 08:10 AM
rankar's Avatar
rankar
Zack do you have the counter wrench as well to hold the fan in place while applying torque too?
Old July 19th, 2015, 08:13 AM
rankar's Avatar
rankar
Old July 19th, 2015, 08:23 AM
Ray_G's Avatar
Ray_G
Ray Gerber
You can usually just use the mandatory absurdly large flat head to counter hold if you don't want to buy that tool.
Old July 19th, 2015, 09:32 AM
huibae's Avatar
huibae
Harold Lee
Jon Snow Badge 1122
So for me, removing the clutch fan first is no longer an option as I have disconnected the pulley and water pump screws.
I wanted to take the water pump, clutch fan and radiator fan out as one unit.
I pretty sure all the bolts are removed but the 6 o clock bolt won't completely come out cause it's stuck on the pulley.
Sucks
Old July 19th, 2015, 11:52 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
If I remember, there should be enough clearance to push the fan/WP/long bolt forward towards the radiator to get out.
Another option is to cut that long bolt as it sits with a hacksaw, Dremel, or reciprocating saw and replace the bolt on installation.
Old July 19th, 2015, 12:10 PM
Departing90
Sasha
95 D90
We have one of these. Amazon.com: Lisle LI43300 Pneumatic Fan Clutch Wrench: Automotive
its cheap and even free when yiu consider the time wasted trying different ways to go about this and damaging pulleys etc.. takes even the most stubborn fan cluch off in seconds! You need an air gun to use it. Or just find a shop that has one or should do and pay them whatever to take it off.
I
Old July 19th, 2015, 10:35 PM
huibae's Avatar
huibae
Harold Lee
Jon Snow Badge 1122
Sorry to hijack this thread.
So I finally got the dang water pump out with clutch fan attached.
Rather than trying to cut the fan clutch out, I was just gonna replace all these parts with new.
Anyone got a source for the pulleys for the water pump and AC?
RN has them but they are $250 total!
ID:	125449   Click image for larger version
Old July 31st, 2015, 12:54 PM
BlackField's Avatar
BlackField
Oscar
D110
why do some guys show wacking it to the left from the front of the vehicle:
Blake Paulson Youtube
another to the right Rimmer Bros TV wacks it to the right:
Im doing this on a 200TDI...so to the right? any tips on holding the pulley. I have an AC pulley also so I don't see a way to use the hole to cram a screwdriver into.
ok this worked to the right on 200TDi:
Old July 31st, 2015, 03:02 PM
Departing90
Sasha
95 D90
On pre 03 Rover V8s including the 04 Discovery if it has a serpentine belt it opens to the left and if it has V belts it opens to the right. The first clip is a bosch V8 with a serpentine belt so it opens to the left.
Old July 31st, 2015, 06:33 PM
smartz
Scott Martz
2004 discovery
CxrcessEEyyteI
Old August 2nd, 2015, 12:33 AM
Departing90
Sasha
95 D90
Welcome to the forum. Looking forward to your 2nd post.
Old August 2nd, 2015, 07:39 AM
I like this one!
Old April 21st, 2016, 11:55 AM
Originally Posted by Ray_G View Post
Worth just buying the wrench in case it ever has to be done again.
Originally Posted by Overlander View Post
get the wrenches. 80% of the DIY jobs you do require that fan to come off. That's the first special tool anybody should have.
VISCOUS FAN TOOL, 32 & 36mm , RNT140 - Rovers North - Classic Land Rover Parts
Received...thanks Zack
Old April 21st, 2016, 05:02 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
http://www.defendersource.com/forum/...3&d=1459059549
http://www.amazon.com/IceToolz-4x-He...=sr_1_1&sr=8-1
That is bike tool. $18 shipped. I used that to get my viscous fan clutch off. It has 4 sizes built in.
clutch, fan, fan clutch
3.9L V8 viscous fan clutch removal nathanwind Defender Technical Discussions 47 April 18th, 2015 05:31 PM
200Tdi fan with viscous clutch transientmechanic For Sale - Parts 1 October 23rd, 2013 07:55 PM
Viscous Fan Clutch ERR3443 with Fan ERR3439 JohnC For Sale - Parts 1 September 22nd, 2013 12:34 PM
Viscous Fan Clutch NAPA part # Campbell Defender Technical Discussions 4 January 29th, 2011 09:53 AM
Size of fan bolts on viscous fan clutch imeek Defender Technical Discussions 4 September 26th, 2009 03:12 PM
