Viscous Fan Clutch NAPA part # - Defender Source
Old January 28th, 2011, 09:06 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
I need to replace my viscous fan. Anyone know the NAPA part # on the clutch. Also, can I get the wrench at a pepboys or napa......I think it is 37mm....or do I need to order it.
I have a 97 4.0
Rich
------ Follow up post added January 28th, 2011 02:16 PM ------
I have also heard the autozone #922786 for a chevy blazer is a perfect fit and cheap....anyone ever use this?
Old January 28th, 2011, 09:32 AM
Naplm00
Matthew
Dont by the wrench as the metric version. I have a 1 1/4 in (32mm) combo wrench I used for E30 fan clutches that was $11 bucks at sears. The metric version marked as 32mm was $29 bucks.
Same size
Old January 28th, 2011, 09:38 AM
Campbell's Avatar
Campbell
Rich Campbell
Thanks...
pretty sure the bolt is 37MM on the 4.0. Thanks for the tip.
Old January 28th, 2011, 05:43 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
V-belt rovers have a 32mm head on the fan and the serp ones use a 36mm. It doesn't matter what engine you have....it's the belt set-up that determines the fan/nut size.
Old January 29th, 2011, 09:53 AM
Campbell's Avatar
Campbell
Rich Campbell
Thank you.
clutch, fan, fan clutch, part
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Size of fan bolts on viscous fan clutch imeek Defender Technical Discussions 4 September 26th, 2009 03:12 PM
Viscous clutch part #ERC5708 brand new in box $50 draaronr For Sale - Parts 0 January 1st, 2005 11:21 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
