Viscous fan clutch bolt! - Defender Source
Old August 19th, 2017, 08:34 PM
bobjackson
Bob
D90
After an hour of messing with the viscous fan clutch bolt, any help to keep the pulleys from spinning while trying to knock the nut loose? Yes, working at it knowing itís a reverse thread. Even tried chisel on the edge of the nut. Not budging for me.
Those of you who have replace, what are you doing to keep the pulleys stationary??
Thanks for the help.
Old August 19th, 2017, 08:35 PM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
Impact gun spins it right off, but protect yourself from the fan!
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
Old August 19th, 2017, 09:47 PM
Naplm00
Matthew
https://www.zoro.com/irwin-vise-grip...RoCqbAQAvD_BwE
For the super stubborn
https://www.walmart.com/ip/Craftsman...&wl13=&veh=sem
For the semi stubborn
Hold the water pump pulley with either ,place correct size wrench on nut and tap it with a hammer. Bingo Everytime
Be aware the chain type will scratch that pulley
Old August 20th, 2017, 08:33 PM
bobjackson
Bob
D90
Thanks Matthew - may have to look at one of those.
Old August 21st, 2017, 10:03 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
I fought with this thing for years...until I bought a cheap open end 34mm or whatever it is and use in along with an old piece of garage door opener drop arm.
Drill out the hole in the bit of metal so it fits over the bolt head on the water pump pulley (stops it turning when held against the side of the pulley) and grab the Big Nut with the wrench.
Once in a while I'll have to resort to the dead blow hammer, but usually just old guy muscle will take things apart.
Old August 26th, 2017, 01:48 PM
bobjackson
Bob
D90
Figured I post an update since many of us deal with this bolt in different ways. For me, getting a decent wrench with some length for leverage. Came right out.
clutch, fan, fan clutch
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Size of fan bolts on viscous fan clutch imeek Defender Technical Discussions 4 September 26th, 2009 03:12 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
looking for a viscous cooling fan drork Wanted 1 July 1st, 2004 11:29 PM
