viscous coupling - Defender Source
Old April 21st, 2005, 09:58 AM
viscous coupling
too burnt from the holidays to search. when I turn off the truck should it be hard to turn? I thought I read it would be at some point in the past but cant recall. thanks peoples
Old April 21st, 2005, 10:08 AM
It should be hard to turn when the engine is warm, and easy to turn when everything is cool. Best to check it before starting in the morning, then take it for a drive, when it warms up try spining it again, it should be much harder.
Old April 21st, 2005, 11:14 AM
i tried to turn it when its hot and it spins freely, there is some shop time on the horizon anyways just add to the list i guess. thanks.
Old April 21st, 2005, 03:32 PM
jimbemotumbo's Avatar
jimbemotumbo
Jimbe Motumbo
97 D90 Wagon
In my experience a viscous coupling is much preferred over a non-viscous one, regardless of the degree of "warm-up".
Old April 22nd, 2005, 10:36 AM
ISUZUROVER
Ben
1968 IIA 109" x-military
The viscous coupling won't necessarily be hard to turn even when the truck is hot, it depends how much difference in motion between the front and back wheels you had when driving.
If you have a trolley jack, an easy way to test it is to jack up one of the front wheels (just off the ground), and VERY SLOWLY AND GENTLY try to drive. If the viscous coupling isn't working you won't go anywhere, if it is working properly it should lock up after one or 2 turns of the wheel of the ground and the rear wheels should start to drive.
Cheers,
Ben.
Old April 22nd, 2005, 05:29 PM
Trevor Tarr's Avatar
Trevor Tarr
Trevor Tarr
1997 D-90 4.6 NAS ST
Ben, they're talking about the viscous coupling that drives the radiator fan (the "fan clutch").
Old April 26th, 2005, 07:03 AM
ISUZUROVER
Ben
Ahh... Thanks Trevor.
Cheers,
Ben.
Viscous Coupling swap - anything I should know? Emerson00 Defender Technical Discussions 1 December 10th, 2007 10:24 AM
Viscous Coupling & Fan javelinadave For Sale - Parts 3 September 29th, 2005 01:06 PM
97 4.0L viscous coupling removal javelinadave Defender Technical Discussions 5 May 4th, 2005 09:33 PM
looking for a viscous cooling fan drork Wanted 1 July 1st, 2004 11:29 PM
My viscous coupling be broke! dboehme Defender Technical Discussions 6 October 6th, 2003 11:32 AM
