Visc. Clutch vs Electric Fan - Defender Source
Old May 28th, 2008, 10:01 PM
snurp
Keith Kuboske
94 D90 ST Arles Blue
Need to replace the fan clutch on my 94 D-90 as it continues to overheat and all things point that way as the fan can be stopped when vehicle is hot . Was concerned about the issue of the clutch problem arising again and would consider getting electric fans instead. What model flexalite would be needed? Is this the better solution of the two?
Thanks for all the help!!!
K Kuboske
Old May 29th, 2008, 08:05 AM
The flexalite 210 fits like it was made for the truck. When I used them, I wired it wth a 3 way switch so I could force them off, on, or via a thermostat. Search the forums for more info but you can get a VW thermostat that trips at the right temperature and replace the A/C thermostat with it.
In my opinion, replace the clutch. Why? It should last another 10 years, and if that was the only problem then your done. If there are other issues, the e-fans just mask them, or delay them, but eventually they will cause damage worse than if you address them now (yes the e-fans work that well). At least in my case this was what happened. The e-fans are also more electronics to go wrong.
If you have a valid reason to go electric (like a engine conversion with higher cooling requirements or space issues) they are well worth it though.
charles
Old May 29th, 2008, 08:56 AM
snurp
Keith Kuboske
No special needs for cooling or space, just have read and heard of multiple failures of the fan clutch sometimes within months of replacing. As I will probabaly have to have the dealership to install, it gets expensive quickly. Has the problems with these clutches been resolved?
k kuboske
94 D90 ST White
02 Disco II
Old May 29th, 2008, 08:59 AM
Why dealer install? Go to autozone and get a generic fan removal kit (you can rent). It's an easy job with the right tools.
charles
Old May 29th, 2008, 10:00 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Fan clutches are not something that the dealer needs to install--they are an easy DIY. They should last a fairly long time and are not prone to too many failures except by age. They are a "consumable" that every 10 years or whenever you need to replace.
My opinion on electric fans, however, is opposite of Charles. I know tons of people using them and have not heard of failures any more often than fan clutches--just the opposite, actually--I have never seen one fail although I am sure they do.
The are vastly superior for any engine on hot trails since you are idling so much (mechanical fans turn slower at idle) and the electric fans don't have any problem keeping your engine cool. You can shut them off for water crossings. Mine, like most people I know, are on a temp sensor for and completely automatic operation with an override switch (mainly for water crossings). I wired my 210 model up such that each fan is independently wired/fused in case one goes out, the other will work. IF one failed (5 years and counting), you can usually find spares or be able to get one in a day from most Checker Autos and other auto dealers. They take less power to run than mechanical fans from your engine, but you will have a higher load on your alternator (which in turn also puts a little more resistance on your engine.).
IMO, get a Flexlite:
Advantages: Switchable, keeps engine cooler under idle, superior air flow/cooling, less engine drain, more engine compartment room to work on truck, no more fan clutches to worry about.
Negatives: One more electric component. Then again, you are replacing a mechanical one that DID fail...Little more cost, slight install hassel (there is a good write up on this page to walk you through it, though).
Old May 29th, 2008, 10:04 AM
Not knocking e-fans or flexalites - I ran them for a while and they worked very well. Everything Chris says is true.
One more data point though - when on, they are LOUD.
hth
charles
Old May 29th, 2008, 10:11 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I have twin Kenlows on my series. They are excellent.
Old May 29th, 2008, 12:45 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I also run the Flex-a-lite fans too. Not mentioned here though is that it really clears up a LOT of room in front of the engine. Makes maintenance in that area sooooooooo much easier.
My oil line fix
My 100k stopped odometer fix
Old May 29th, 2008, 02:31 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
FYI-you can get thin bike wrenches that fit the nut for the clutch prefectly at any bike shop.
You can always keep the fan clutch and add a pusher fan on the front of the rad if you dont have A/C.
Old May 29th, 2008, 04:24 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
charles
http://www.defendersource.com/forum/...gen+thermostat is the thread Charles is refering to. Now I thought that the thermostat for the A/C was actually to force the A/C electrical fan to start when the engine was overheating..... I guess I'm glad I read this threat as I thought I had a fail safe for the engine overheating.... I will check if there is a way to have the two options: use the thermostat to start the A/C fan around 92 Celcius to increase air flow _and_ prevent the A/C compressor from starting around 108 Celcius.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 29th, 2008, 04:36 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Does anyone know of a step by step write up on replacing the fan clutch. I have the part, but have been too chicken to try it...
I can change my oil & plugs though
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old May 29th, 2008, 04:57 PM
MonLand
Loic Fabro
It's easy, you can figure it out.
- undo the fan shroud (yes but twisting it, you can remove it without removing the fan/anything)
- use your wrench to undo the fan/clutch assembly. There are two types of fans: serpentine vs. not-serpentine engines (4.0 vs. 3.9L) -> clockwise vs. anticlockwise; do a search to know which way you should turn, basically, you need to turn in the _same_ way your engine would make the fan turn)
- remove the fan / fan clutch assembly
- the fan is "fragile" pay attention at not braking it
- undo the 4 (6?) bolts that hold the fan to the clutch
- follow the steps in reserve order to put everything back together (might want to to put the shroud at the same time as the fan this time?)
There is probably a write up in the FAQ with pictures on this site....
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 29th, 2008, 05:06 PM
Hans's Avatar
Hans
Hans Haase
The nice thing about that switch is that it's compatible with those used in some VW's. You can put in a lower temperature switch, and have the fans come on around 170 or so if you want. Of course, when I did it.... the brand new switched failed 3 days later and I just have the damned things turn on whenever the truck is running.
My oil line fix
Old May 29th, 2008, 05:08 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Mine failed on a trip to the beach and I didn't realize it untill i got back a week later and 500 miles later.
Jimmy Buffett
Old June 3rd, 2008, 09:53 AM
snurp
Keith Kuboske
Does anyone know the difference in the Visc. fan clutch that Atlantic British sells for $139 vs Rovers North $199 vs Land Rover OEM at $400+? Does not seem like that there would be that many manufactures of these clutches...still have not decided which way to go on the fan yet.
K Kuboske
94 D90 ST White
02 Disco II
Old June 3rd, 2008, 10:21 AM
flippedrover
Tyler
'94 D-90
Dealer markup would be a big one.
Jimmy Buffett
Old June 3rd, 2008, 02:24 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I have found that British Pacific usually has the same or better prices on most maintenance stuff. For instance, that fan clutch is 129 and they charge actual shipping. however, I really like Atlantic British and their website, tracking, prices, etc.
Not sure what to say about Rovers North website and prices
Old June 3rd, 2008, 03:29 PM
Would these e-fans be viable for a turbo diesel as well? I really like the idea of turning the fans off for water crossing. I've been stung by the flailing clutch fan hitting water and shredding the radiator before. I'm curious as to what the metrics are for air throughput on engine versus electic fan.
Old June 3rd, 2008, 04:15 PM
Sure. For a TDI get a Taurus fan. Cheap and moves a tons of air. Way more air than the engine will ever need and a perfect size for the radiator.
Here is a write up for my 200TDI, http://www.landroveraddict.com/smf/i...topic=369251.0
Old June 3rd, 2008, 04:37 PM
John,
Thanks for the info. I can't however take you seriously when your avatar is a pink D90.....
clutch, electric fan, fan
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Did 1995 SW D90s come with an electric fan? arbik Defender Technical Discussions 8 March 1st, 2005 01:27 AM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
