Violent shaking d-90 - Defender Source
Old August 11th, 2011, 07:56 PM
bar11's Avatar
bar11
rob grentz
1994 defender 90
When I hit a bump at about 55mph or greater the front passenger side starts to bounce and shake like crazy (good thing I don't have a baby I'm talking shaken baby kind a shaking) and it is worse or starts at a lessor speed if I'm cornering and hit a bump. any suggestions I'm thinking shocks and springs I had the shocks replaced some time ago and am running on the original springs 126.000 miles and its a 94 d-90 thanks in advance ROB
Old August 11th, 2011, 08:11 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
It's called "death wobble" and usually due to one (or a combination) of 3 things:
1) Swivel Ball Bearings shot/wrong preload
2) Wheel Bearings shot/loose
3) Bad Shock with no dampening
Old August 11th, 2011, 08:15 PM
bar11's Avatar
bar11
rob grentz
1994 defender 90
DEATH WOBBLE?? now that doesn't sound good? Thanks is there a way/test to determine which death wobble it is?
Old August 11th, 2011, 08:18 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
You say it's the front passenger side... Does that mean the steering wheel doesn't vibrate or oscillate at all?
Old August 11th, 2011, 08:23 PM
bar11's Avatar
bar11
rob grentz
1994 defender 90
not really the it seems that if I was to look at it while its shaking the front pass wheel would be bouncing in turn bouncing the whole truck there is a slight shaking in the steering wheel as this happens but not like I would think I am able to maintain control till I slow down to about 45/50 and it stops and then I can resume warp speed landrover style
Old August 11th, 2011, 08:26 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Also check tire pressure first. Mine will sometimes do that if the pressure gets low
Legend in My Own Mind.
Old August 11th, 2011, 08:37 PM
navydevildoc
Neill Thornton
Yup.....
To check the bearings:
That video shows the exact sound and movement... your tire should not be able to move at all or make any clunking noises! Make sure you jack up the tire off the ground first of course.
You might be able to tell between the swivel ball and the wheel bearing if it only clunks up and down and not left to right.
Old August 11th, 2011, 09:09 PM
gravitysucks's Avatar
gravitysucks
Andy
94 D90
Mine had similar symptoms a while back, front poly bushings were shot. I replaced the bushings and haven't had a problem since. Might be worth looking at.
Old August 11th, 2011, 09:45 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Check the tightness of the Pan Hard rod bolts and the condition of the bushings too.
Old August 11th, 2011, 09:56 PM
Tire pressure is critical most likely its the swivel pins or steeeriomg damper. Depending on your miles it might be time i fought all of this for a while. Rebuilding swivels hubs and front end bushings my 90 handles like an m3
Old August 11th, 2011, 11:52 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Concur with pretty much all of the above.
Best bet really is to just systematically inspect all the front suspension bushings, steering components, swivel components, bearings, etc.
Remember too that this many times is a cumulative effect of multiple component failures, so even if you find something that's totally hashed..... keep going with the inspection.
Any other symptoms that may go along with it? Does it pull at all to either side, and if so is it all the time or only while braking? Brakes work ok, or do you have to press them a couple times sometimes (particularly after a turn)?
If you haven't done it in a long time, it's never a bad idea to at least re-pack and re-seat the bearings in the front. Just make sure to read up on the procedure, and get the correct hub tool for it. Too loose and it causes odd braking, too tight and it burns the bearings. It's not hard to get it right, just need to be familiar with what to look and feel for as you do it.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 12th, 2011, 08:05 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
It's not the steering damper.
Land Rover steering dampers have nothing whatsoever to do with death wobble, that's not their purpose, despite people perpetuating the myth that a new one can be a fix for wonky steering.
A Land Rover with steering components in good shape doesn't even need a steering damper for on tarmac driving.
Causes of wobble are (from easiest to correct):
loose steering box fixings (not so much but can contribute)
loose hub bearings
loose front suspension bushings/bolts (particularly panhard rod)
too light preload on swivel pins.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 12th, 2011, 10:25 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Add tyre failure to the list. The cords in the body of my General TR's failed last year - caused a wobble to end all wobbles. Like the other posts - check everything but my money is on the shock on that side or possibly the mounting turret on an aftermarket one the spot welds can separate and allow the top plate to pull down and it will cause a lot of banking, clanging and general lack of damping on that corner.
Concur with Antichrist on the steering damper.
It won't be the spring though.
Mike Hammond
Old August 12th, 2011, 10:26 AM
Agree but they are a nice band aid
Old August 12th, 2011, 11:34 AM
red&yellowrovers's Avatar
red&yellowrovers
Joe Still
95 D90 NAS 3.9l ST AA Yellow #2719
Death Wobble
I'm new to Defender but after years with a 95 Disco I can tell you with confidence a new steering box fixed the problem permanently. I went to 150k without anyu other front end repairs other than alinement. js
Old August 12th, 2011, 11:43 AM
bar11's Avatar
bar11
rob grentz
1994 defender 90
Thanks guys for all the great info , looks like I gots my work cut out this this week /weekend
Old August 12th, 2011, 12:54 PM
Prolly the Panhard rod bushings. EZ fix.
Old August 13th, 2011, 03:39 PM
chrisconnie's Avatar
chrisconnie
Adam Hairston
97 LE #127/300
X3 panhard rod bushings.
To test: have someone gently turn the wheel back and forth while parked. From underneath look at the linkage end for movement that doesn't move what they are attached to. It will make sense when you see it and you will know what to tighten.
Old August 13th, 2011, 03:46 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
[QUOTE=Antichrist;295197]It's not the steering damper.
QUOTE]
You are right about the damper not being a cause. It is, however, a great benefit to the steering stability of the vehicle on or off road. In addition, as it's name implies it can help absorb steering input shocks that would otherwise be transmitted directly to the driver or steering components.
Old August 13th, 2011, 05:07 PM
I recently bent/destroyed my steering dampener @ rausch creek and had to unhook it 2 weeks ago. I haven't had a chance to swap it out and have put 1000 miles on the truck. Definately feels different !
90, d-90
90 & 110 Parts Sale Extravaganza Wolf Fabrication For Sale - Parts 57 October 16th, 2012 09:35 AM
Electrical Issues & the best repair manuals for a 1995 D90 agavelvr Defender Technical Discussions 18 August 23rd, 2011 12:54 PM
1994 Defender 90 - Hardtop and A/C silver_defender For Sale - Vehicles 4 August 14th, 2009 03:31 PM
90 parts blowout Ren Ching For Sale - Parts 35 March 9th, 2009 12:39 PM
110 for sale(maybe) or my 90 mpsteil Misc. Chit-Chat 6 January 29th, 2009 10:43 PM
» Defender Registry
Roi
Bassi
D90
NPT90
Add your Defender
