VIN Location Help - Defender Source
Old April 30th, 2013, 05:21 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
VIN Location Help
I just had a shake up at the Motor Vehicle Bureau here in Maine. Although the previous title, all customs paperwork and the VIN plates on the truck match, its coming back invalid.
Now the local PD has to come and verify it in at least two places, one being on the frame. Before I start searching with a wire brush, can someone point me to its general location?
The truck was previously titled in Ohio and it was imported prior to it being titled there....but everything matches. All the import documents from the UK, MOT, US Customs etc. etc....
Many thanks in advance.
Josh
87 EX MOD 110
Old April 30th, 2013, 05:24 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Stamped into the outer side of the frame just in front of the Passenger side front wheel.
Stamped onto a plate riveted to the top of the bracket that holds the brake booster under the hood.
These are the 'official' ones.
There may also be a plate affixed to the side of the seat box as its an Ex-MOD truck but that's from the MOD, not LR.
Edit - Pass side being the side closest to the kerb here. Left hand side if you stand facing the truck.
Old April 30th, 2013, 06:02 PM
x2 what Ian said. Also, in the future you can use the search button and save yourself a ton of time. Just searching "VIN location" brings up the same answer(s). Welcome (back) to the board.
Old May 1st, 2013, 04:53 PM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
The VIN is stamped, here -
Paul.
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old May 1st, 2013, 05:19 PM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
I'd like to add to this thread. I'm having the same issue. I have an '83 ROW 110. Put a galvy frame on (so nothing on the frame). And I'm the third owner in the states, so no import paperwork. Only location of the VIN is the horn over the brake booster under the hood. Truck is titled in FL, have a copy of the previous title in NY. Given those circumstances, how do I prove to the police that my truck is legit with two VIN locations?
-Ryan
Old May 1st, 2013, 05:37 PM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
Maybe if you have a box of donuts sitting on the hood and just start some off-topic conversation in the beginning, the officer will just end up not giving a rat's ass and sign off for you...
Old May 1st, 2013, 05:40 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Get it stamped on?
Mike Hammond
Old May 1st, 2013, 05:43 PM
BEIS's Avatar
BEIS
RYAN BEIS
Haha! That just might work...
Originally Posted by mikeslandrover View Post
Get it stamped on?
Interesting idea. Anybody have a picture of their VIN on the frame so I could maybe do something up similar size, etc?
-Ryan
Old May 1st, 2013, 05:50 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
"Prove"? You cant anymore since the only permanent VIN has been removed with the frame and you have no documentation to support a transfer of ID.
You could stamp one on as Mike suggests. Its possible it could be questioned if its not an exact match for a factory stamp and somebody knows what they are looking at (which is unlikely).
In the situation you are in I would guess that stamping one on an hoping it passes scrutiny is probably your best bet. Are you needing to re-title it and require a VIN inspection or something?
Old May 1st, 2013, 05:53 PM
BEIS's Avatar
BEIS
RYAN BEIS
Exactly. I moved to Louisiana, and if you get a Louisiana plate, you have to also have a Louisiana title. Plus....you have to re-pay the sales tax...(total BS if you ask me).
-Ryan
Old May 1st, 2013, 07:52 PM
Oannes's Avatar
Oannes
Aaron
1997 NAS D90 (Original Dream Car)
Just had my 84 110 paperwork kicked back here in CA for the same thing. Took it to the DMV they did an inspection, signed off, took my $1699 in fees, gave me plates and registration... Then a week later all my paperwork shows up in the mail saying I need to go to the CHP for another inspection???
Aaron
We make a living by what we get, we make a life by what we give. Sir Winston Churchill
1984 Defender 130 (In the middle of build)
1988 Defender 110 CSW (Original)
1964 Series IIa 109 5 door (South Africa in a thousand pieces)
1973 Series II 109 5 door (Australia)
1997 NAS Defender 90 (Already sold so)
2013 Chevrolet 2500HD (work horse)
Old May 14th, 2013, 01:36 PM
BEIS's Avatar
BEIS
RYAN BEIS
Issue solved. State police did a physical inspection. Police officer looked at the VIN above the brake booster on the vehicle, looked at the previous state title, then filled out a form. Took the form to the DMV. Slight issues at the DMV, because the gray market VIN was not able to be put into the system. The lady was very diligent and consulted with the senior ladies to put the vehicle into the system. Good to go.
Only hang up was with the state inspection. All original engine components need to be currently installed (including the dual carb intake...)....talked to the inspector regarding this: most people replace their engines with older components, thus making their vehicle worse off, rather than better. Therefore, the inspectors have to ensure that the original engine and components are present, even if the engine was updated or modified for the better...doesn't make sense to us enthusiasts that upgrade components to make them safer/more reliable... Overall, good to go, and waiting for the title in the mail. Hope this helps those with 25+ year old ROW trucks.
-Ryan
Old May 14th, 2013, 01:54 PM
The Dro
Dro
1988 Ninety
Why are you guys getting scrutinized about your trucks when you have a valid State Title?
Or this is normal?
When I title one of my Rovers a few years ago. I had a MD Title with a 7-6 digit number (Assigned ID) and the lady did not even hesitate. I got my VA Title without issues. No PD involvement, no issues.
Old May 14th, 2013, 02:07 PM
jafir's Avatar
jafir
Jafir Elkurd
Or this is normal?
Arkansas didn't give me any issues with a previous Texas title. It took the guys in Texas quite a while to get their title and they did have to do an inspection. Not sure about VIN, but that wouldn't have been a problem because my 90 had 3 clearly legible locations: the brake booster, the frame, and the MOD plate on the seat box.
Old May 14th, 2013, 02:17 PM
The Dro
Dro
1988 Ninety
My truck did not have a VIN. It had an Assigned Identification Number from New Jersey.
The lady did not even look up when writing in the computer.
Well, every state is different and it's a matter of who is behind the counter.
Old May 14th, 2013, 03:06 PM
josh-man's Avatar
josh-man
joshua
typically on the MOD trucks an interior VIN plate is located on the drivers side seat box. My trooper verified the one under the hood and the one on the seat box and just asked me to crowch down and read him the VIN off the frame.
You can get those blank VIN plates too, and stamp it...not sure if its easier to stamp the frame or not but seems like that is a simple and effective way to jump through the hoops each state has their own way of doing to us.
Old May 14th, 2013, 03:11 PM
Wonder if the CBP thing is trickling down to the state and local RMV's.
Old May 14th, 2013, 04:11 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
Oh joy..maybe this is why I haven't received my Maine title yet.
Defender 110
Old May 14th, 2013, 04:13 PM
jafir's Avatar
jafir
Jafir Elkurd
I thought maine didn't issues titles for vehicles older than 10 years old.
Old May 14th, 2013, 04:14 PM
15 I thought. Maine only gives you a registration.
vin
VIN location on ROW trucks Glenn_Guinto Misc. Chit-Chat 6 December 4th, 2012 09:06 PM
VIN / frame question dave_lucas Defender Technical Discussions 6 June 30th, 2005 10:16 AM
Location for ARB Compressor Seriesman Defender Technical Discussions 10 August 15th, 2004 04:09 PM
XM Radio antenna install Location - Where? COSteve Defender Technical Discussions 37 July 11th, 2004 07:50 PM
Run a VIN? Robbie Donaldson Misc. Chit-Chat 3 November 18th, 2003 07:23 PM
