VIN check-no luck - Defender Source
Old August 19th, 2013, 04:48 AM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
VIN check-no luck
Okay, so made the rookie mistake of not running a vin check on the 130- as I only ensured that all the vins matched. The exterior is a new respray, but as I was digging around the interior I noticed original paint is OD green. Also, battery indicator on the dash is 24v, not 12-- but only one battery. Is it possible that this truck is an old MOD? The vin is salldhhf7a904172. When I tried to pull up a history report it said the vehicle was not in the system. Please excuse my ignorance btw, but can anyone confirm or deny my question?
1995 Disco 300TDI
1991 D130 (SOLD)
1997 D90 NAS (SOLD)
Old August 19th, 2013, 06:08 AM
d110pickup
Mike Pado
'97 D90 ST #1153
I can't comment on the VIN but I do know that my NAS '97 D90 has a 24 Volt Battery Indicator, as does my ex-MOD 110.
Mike Pado
I'm not saying that stupid people should die . . . but maybe we could remove the warning labels & let nature take it's course.
Old August 19th, 2013, 07:31 AM
Always go the DIY vin decoding route.
http://www.expeditiongear.co.za/cu5/...%20Number.aspx
Old August 19th, 2013, 07:43 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Try this link.
Try this link:
http://www.expeditiongear.co.za/cu5/...IN-Number.aspx
The other one does not work.
It's easy to translate each number.
According to the site, you are missing a letter before the 6 digit serial number so you might want to double check your vin sequence again.
RDavisinVA
Old September 1st, 2013, 01:18 PM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
Thanks for the info guys. That is the VIN on the title. I still couldn't find history using the VIN but did using the plate number, as I guess plate numbers don't always change with new owners in the UK as they do in the states. Thing is, history is still minimal, pretty much just says Land Rover; Green; Truck and gives accident/theft history (clean btw).
Sorry for my delayed response, as our firstborn little one arrived a couple of weeks ago and I haven't had much dork off time on the web.
1995 Disco 300TDI
1991 D130 (SOLD)
1997 D90 NAS (SOLD)
Old September 1st, 2013, 01:33 PM
jafir's Avatar
jafir
Jafir Elkurd
Can you check the VIN on the chassis or brake booster to make sure it matches? When I plug that into microcat, it doesn't like it, it says VIN not found. When I plug my ex-mod 90 VIN into microcat, it doesn't come up with much, but it at least knows it's a 90, LHD, 2.5NA, manual tranmission.
Old September 1st, 2013, 02:29 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
By 1991 the 130 had it's own designated digit where as earliest examples were sometimes designated as 110 based on the vin. code That said I would think your 6th digit should read K and not H as H is for a 110. The digit you are missing I am guessing is the H or J it should have as the 10th digit to designate year of manufacture (if truly a 1991) and the A as 11th digit is relative universal. Have you done an HPI check or DVLA search that offered up additional info? Is the chassis stamped vin still there?
You did purchase from a dealer so there should be laws on your side I would expect if you believe you were mis-informed about what you purchased.
vin
VIN Check Help NealK Misc. Chit-Chat 6 July 3rd, 2011 01:55 PM
VIN Advice navydevildoc Misc. Chit-Chat 16 November 28th, 2010 04:25 PM
VIN Check Wolf Fabrication Misc. Chit-Chat 0 November 24th, 2009 01:00 PM
VIN check for Imported Defenders? Bozman Defender Technical Discussions 11 June 9th, 2009 11:33 AM
d-90 on Ebay...check it out! boshea Misc. Chit-Chat 5 October 31st, 2003 02:55 PM
