Vibrations again - Defender Source
Old July 1st, 2008, 03:28 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Vibrations again
OK, so I have searched and done some testing, now I need some help. I replaced my rear output shaft seal(transfer case), and a u-joint on the rear. I drove the truck with the diff locked and only the front driveshaft on with no vibes, it did seem as though there was more driveline slack(banging) than before. I put the rear back on and now I get a clicking coming from somewhere underneath and vibes when I get over 25mph. I checked the trans and engine mounts, the seeem fine. both rear uj's are fine(no play) the front uj's seem fine. I had no vibe's before I broke the cv wheeling a few weeks ago.
Thanks in advance
Old July 1st, 2008, 08:14 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Not trying to be funny, I did the same thing but did you check to make sure you tightened all the bolts and that none loosened up?
Old July 1st, 2008, 09:44 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Awhile ago when I did the U Joints on my range rover I was getting some vibrations. It turned out that I just hadn't gotten one of the C-clips seated all the way. Thought I was careful to get them all seated properly, but apparently not.
Old July 1st, 2008, 11:35 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Also make sure the propshaft is inserted in the "correct" direction. This HAS been done incorrectly before. Don't ask me how
Old July 4th, 2008, 09:09 AM
Just wanted to say that when I run one driveshaft only with the center diff lock engaged I too feel more slop than usual. I think this is expected.
good luck,
charles
Old July 4th, 2008, 09:13 AM
Something else to check
I went through all of this and it turned out to be the splines where the drive shaft telescopes in and out. They were shot dispite being well lubed.
110 OME754 - DC driveshaft - vibrations Shearpin Defender Technical Discussions 7 August 22nd, 2008 12:58 PM
Front Diff Vibrations 1of40 Defender Technical Discussions 3 February 6th, 2008 10:41 PM
vibrations and noise Big D Defender Technical Discussions 4 September 5th, 2007 10:13 AM
Vibrations again.. sflash868 Defender Technical Discussions 3 April 22nd, 2006 11:24 AM
Good Vibrations Doug_Paoletti Defender Technical Discussions 6 May 24th, 2004 09:12 PM
