Vibration, whine on shifting question - Page 2 - Defender Source
Old September 22nd, 2012, 08:28 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Here's a new flange
No Mall crawler here
Old September 22nd, 2012, 08:34 PM
Rover110
Steve
1993 Defender 110 NAS #472
Hmmm. My bolts have no trouble sliding back to the case. Perhaps my circlip was missing.
Maybe I'll just order a new flange kit.
Thank for the photos. Where does the flange get grease?
I'm only putting on the Proline replacement. Don't really off road and only have about 1.5" of lift with he new shocks and springs. Thought is might be good to ge a Tom woods shaft but I don't see why for the highway. May try and get my original shaft rebuilt as a spare
Originally Posted by rovertek View Post
Old September 22nd, 2012, 09:42 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
My bad thats a later model flange ....yours should be similer dont sweat it just pull the flange off and replave the bolts some had the clip and some just have a mud shield ...proline shaft is fine ....
Old September 22nd, 2012, 09:45 PM
Rover110
Steve
So the only hing holding flange on is the large nut. I know I'm harping on this but I'm curious. Is there any mechanical reason the bolts can't be used the other way.
Old September 22nd, 2012, 09:55 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Just the large nut i think its 27 or 31 mm......now that i think about it the head of the bolt is up against the flange if you put it opposite you wont be able to tighten the nut side...a couple more min of work and you could put it back orig....
Old September 23rd, 2012, 10:19 AM
Rover110
Steve
cell phone shots
I tried to get some shots of the worst of the UJ's. Not sure if the damage can be seen. To my untrained eye they look like the 1993 originals.
Name:	2012-09-23 09.32.50.jpg
ID:	57973   Click image for larger version
Name:	2012-09-23 09.32.59.jpg
Name:	2012-09-23 09.33.11.jpg
Old September 23rd, 2012, 10:30 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
O man thats hammered.....the new shaft will come with that flange ....
Old September 23rd, 2012, 10:36 AM
Rover110
Steve
I had to take the grinder to it but knew the new one came complete. Now off to get the sway bar parts. Have to figure out if I can do the a-frame ball joint on the street...
Old September 23rd, 2012, 10:40 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
That last ball joint i did i had to remove the complete a frame to install.... takes little longer but much easier when its on a bench infront of you ......
Driveline Vibration johare Defender Technical Discussions 20 March 31st, 2006 09:27 PM
vibration question stevewhitaker Defender Technical Discussions 10 January 18th, 2005 04:25 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Drive Line Vibration reggie Defender Technical Discussions 4 May 13th, 2004 12:27 AM
