Very high idle, sorta, just appeared yesterday - Defender Source
Old December 6th, 2004, 05:00 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Well, I wanted to check for a part number on the ECU connector.... so I disconnected it, saw nothing useful, and reconnected it.
Now, since then, when the truck is cold it idles at almost 2k RPM. As it warms up, the idle kicks down in 250-300rpm increments and eventually ends up back at the usual 750rpm. Prior to this, it ALWAYS idled at 750rpm all the time.
Is something wrong, or WAS something wrong and I am back to normal now?
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 6th, 2004, 05:05 PM
Nope, mine does this after the battery has been disconnected or the ECU. It stops doing it after a few days.
Old December 6th, 2004, 08:02 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Ditto--mine took about a week to relearn itself.
Old December 6th, 2004, 08:16 PM
Also, never discount the obvious. Mine was doing this once, but it was only because the accelerator pedal had pulled out a grommet along its path (close to the throttle body) and was stuck partially open.
idle
high idle only when moving question.. wantone Defender Technical Discussions 14 November 20th, 2009 07:03 PM
High idle problem MAF ? TPS? other? MonLand Defender Technical Discussions 30 February 5th, 2007 03:33 PM
High Idle on 97 D90 ndhlp Defender Technical Discussions 3 November 26th, 2006 11:59 AM
High Idle after Highway Cruise + stalling cellulararrest Defender Technical Discussions 3 October 11th, 2006 05:05 PM
High Idle tron Defender Technical Discussions 5 February 15th, 2006 03:33 PM
