Verifying authentic d130 build - Defender Source
Old May 26th, 2015, 11:38 AM
edemusmaximus
Ed O
1990 Defender 90 200tdi
I recently sent a web inquiry to the British Motor Heritage folks for a 1992 d130 I am trying vet. As I sent the VIN to them, this was their response:
Further to your Web Research request the build date recorded for chassis number SALLDKAG7JA/xxxxxxx is not recorded in our records but the vehicle was despatched from the factory on 27th February 1992 and went to Land Rover Fleet.
The colour is not recorded but I can email our Land Rover contact next week (they are closed this week) and get the colour for you then.
We don't have any records of registration dates so I can't help with that question.
Regards
Jan Valentino
Archive Research
If the chassis does not show up in their records, should that be a big cause of concern for me?
Old May 26th, 2015, 12:05 PM
johan's Avatar
johan
johan
2009 Range Rover
I am not a specialist, but according to all the books I have, the "G" in the VIN stands for 2,25 D (10J ) engine.
THey didn't make these engines anymore in 1992.
FOr special order they did make the 2.5D but then it should be a "C".
(or an "F" for 200 Tdi, which was the most common)
sure you got the correct VIN ?
Johan
Old May 26th, 2015, 12:45 PM
edemusmaximus
Ed O
I did record it down correctly...the VIN was the only number I gave them, and they were with that able to relay the dispatch date, but that the chassis wasn't in their records...that just doesn't make sense to me...was hoping to get more insight on that bit
Old May 26th, 2015, 04:41 PM
johan's Avatar
johan
johan
2009 Range Rover
Double checked my records of the VINs of all the Land Rovers I have had trough the years. + I have owned a couple with the "G" in the VIN for the engine code and these were all 1983, the only year this engine was build.
The last 6 digits are just a number and are given in sequential order over all the different models. I have seen dealers working with only the last 6 digits to identify the cars. I can image the dispatch records only used this number so they were able to inform you about this release date.
G en C look very similar in the font LR is using, see two examples below.
You might want to try the same question but with the C, see what they come up with.
ID:	121650   Click image for larger version
Johan
Old May 26th, 2015, 04:56 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
TO add onto what Johan mentioned, one digit off and it ruins the vin decode typically.
Old June 1st, 2015, 06:21 PM
Ed:
It may help, the DVLA (https://www.gov.uk/get-vehicle-information-from-dvla) may have records under the UK tag/registration number that will show you when the vehicle was first registered and some other pertinent information (color, etc). I've pulled my UK tag up in there before, and it is accurate.
Not exactly what you were looking for with the vin information, but it may be a place to start.
Authentic Bear Trap solarguy The Flea Market 19 March 9th, 2016 07:43 PM
Odometer verifying Anschluss Defender Technical Discussions 3 September 3rd, 2013 12:36 PM
Authentic Heritage Grill d90boy For Sale - Parts 10 May 6th, 2013 02:32 PM
Verifying temp gauge with IR Thermometer Overlander Defender Technical Discussions 7 September 15th, 2011 02:17 PM
1993 D130? Philo856 The Flea Market 4 March 31st, 2008 12:24 PM
