vent seals, which is better? - Defender Source
Old September 23rd, 2011, 02:20 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
I have an '84 90 with perished on-bulkhead vent seals (believed to be original equipment). I ordered up a new set and was sent the on-door variety. After reviewing previous posts, it is unclear which might be better. Has anyone gone from the old style to the new style with success or should I stick with the bulkhead-mounted variety?
Thanks!
Old September 23rd, 2011, 11:23 PM
Get the rubber series ones ... Be careful when you glue them on ... Live leak free ... At least from the vents!
Old September 25th, 2011, 10:42 PM
i just used the stock ones which go on the flap (the series ones go on the body i i rememer correctly)
easy job, remove the exo-cage cross bar and take the out from the outside. remove old ones, clean off glue and reapply carefully)
they don't leak.
95' D90 - daily driver..
seals, vent seals
Vent Seals Weldon Defender Technical Discussions 6 March 16th, 2010 01:24 AM
Vent & Door Seals Question Stmpede Defender Technical Discussions 6 November 14th, 2008 10:05 PM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
Replacing Vent Seals TND90 Defender Technical Discussions 3 January 14th, 2006 08:02 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
» Defender Registry
Anni
Elbee
LRNA04
lrna04
Add your Defender
