Vent Seals - Defender Source
Old August 16th, 2009, 11:27 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Vent Seals
Guys,
I'm in need of some directions? Looking to replace vent seals. In the Custom Mods section there's a thread on what/how to replace but it appears that NR doesn't sale Part # MUC 4299.
Question; What other alternatives are there?
I just do not want the foam seals, rather have rubber just like the thread in Custom Mods. Any ideas on where to find?
http://www.roversnorth.com/store/sea...arch+for%21%5D
http://www.roverparts.com/Parts/3896.cfm
Weldon
Old August 16th, 2009, 12:52 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Rovers Down South
http://www.roversdownsouth.com/series.htm
Old August 16th, 2009, 06:58 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Dave, Is corect, you can use series rubber seals for that...Weldon
Old August 16th, 2009, 07:47 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
did it over this past winter. went with the rubber series gaskets as replacements. Got mine from rovers down south. great improvement over the foam ones. I had a little difficulty getting them in place, turns out silicone is not a good idea. went to an auto body supply shop and got the 3m stuff they use to set windshields and it is awesome. set really fast. they are a great fit, great seal, and a huge improvement over the originals.
This is where I'm supposed to write something witty and funny; or something.
Old August 17th, 2009, 09:15 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Thanks Guys...
Forgot about checking Rovers Down South. Just checked, $20 per seal, not bad, could be the cheapest fix yet (cost wise).
Weldon
Old March 16th, 2010, 01:17 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Do you have to remove the vent flaps in order to replace the seals or did you replace them with the vents in place?
Old March 16th, 2010, 01:24 AM
Rugbier's Avatar
Rugbier
Gustavo
You can replace them with the vent on
You either remove the screw off the back or easiest take the pin of the bulkhead, slide the rubber over it, replace pin, then apply bonding material of choice , let it sit for a few, then close the vent
NO SIGNATURE
seals, vent seals
FS: Vent Seals fleabus For Sale - Parts 2 January 3rd, 2010 07:07 PM
Vent & Door Seals Question Stmpede Defender Technical Discussions 6 November 14th, 2008 10:05 PM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
Replacing Vent Seals TND90 Defender Technical Discussions 3 January 14th, 2006 08:02 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
