Vent Seals - Defender Source
Old October 12th, 2008, 04:29 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
Angry Vent Seals
So I finally got around to doing this. I guess with winter coming I was more motivated. Searched and read all posts for any thoughts or problems that I didn't think of. I decided to go with clear silicone as an adhesive. BAD IDEA!!!!!!!!! it doesn't set nearly fast enough. I thought liquid nails was a bad idea cause I tend to be a little sloppy and wasn't sure how well it would clean up. but the series III gaskets need to be stretched a little to get in the corners and the silicone just doesn't set fast enough. Aside from liquid nails what types of other adhesives could I have used? once the silicone dries and I peel it all off I'll have to use something....but what?
This is where I'm supposed to write something witty and funny; or something.
Old October 12th, 2008, 06:43 PM
SOUTHPAW26
Kelly
1994 D90-1993 NAS 110#280
Black 3M Super Fast window Urethane.
Old October 12th, 2008, 06:56 PM
JBOD77
Jonathan
what about hot glue?
Old October 12th, 2008, 07:12 PM
liquid nails.
Old October 12th, 2008, 07:29 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Lots of clothespins to hold
legend in my own mind
Old October 12th, 2008, 10:13 PM
JBOD77
Jonathan
not a bad idea at all. actually since I run a building materials store perhaps 1" spring clamps... I have immediate access to those....So 3m window weld from the auto body shop and 1" spring clamps from my shop....case of beer and viola I'll have vent flap seals....and a buzz.....nice!
Old October 13th, 2008, 07:56 PM
JBOD77
Jonathan
not good. How the f*ck do I get all the silcone off the truck. My whole shit is screwed.... it's everywhere!
Old October 14th, 2008, 02:33 PM
Silicone will rub off.
Use super black weatherstrip adhesive. If you pass out from the sent of it, you have the right one.
Old October 14th, 2008, 02:55 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
i used regular contact cement (clean both surfaces and apply to both. holding strong for years.
Old October 14th, 2008, 02:59 PM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
Gorilla glue. Just remember it expands big time.
Old October 14th, 2008, 03:19 PM
themaxx's Avatar
themaxx
Ade
94 ST
What's wrong with the stuff that comes with the vent seals?
Old October 14th, 2008, 04:25 PM
For god sakes, don't use anything that will make the job a bigger PITA next time. I'd say gorilla glue and quickcrete are not good choices. Silly-cone is not the best for most things either.
Old October 14th, 2008, 04:31 PM
JBOD77
Jonathan
nothing came with my vent seals just 2 pcs of rubber. these are the series 3 vent seals...not the shit foam ones that come standard. I bought the 3m window weld stuff. when i realized that the silicone wasn't working, I tried to wipe it off. So now, I have a very thin smear of silicone all around the vent itself. rubbing it off is freakin crazy. I'm gonna be there for ever, but my arms will be buff. [img]images/smilies/biggrin.gif[/img]
Old October 14th, 2008, 04:53 PM
themaxx's Avatar
themaxx
Ade
94 ST
That's what I bought when I replaced my seals, I thought it came with adhesive. Anyways, the 3M seal adhesive is definitely the way to go.
It's a learning experience...just an annoying one.
Old October 14th, 2008, 06:00 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I third or fourth the 3M seal adhesive. You can get it at most reputable auto parts stores. I've used it on several of my Jeeps with no issues. Sticks anything to anything, use clothes pins to hold.
Semper Fi!
Old October 14th, 2008, 10:19 PM
JBOD77
Jonathan
OK one last insanely retarded question on this topic. I read the rite up in the custom mods section. while over at DWEB trolling the defender section, I noticed that someone posted on the topic and was told that the grooved side faces out? is this right?
Old October 17th, 2008, 07:53 AM
JBOD77
Jonathan
Definitely a learning experience, but a good one. Just another reminder that having the right materials will make ANY job that much easier. After developing the perfect blend of goo-gone, goof-off, and rubbing alcohol, I removed all of the old silicone. Guess I'm fortunate I didn't die for the blend of solvents. Smells kinda like gasoline if it were made from oranges. 3m super fast window weld is absolutely the shit! Holds tight sets fast and cleans up nicely with rubbing alcohol. Seals are finally installed, and tonight I'll reset the vent flaps! Thanks all!!!
seals, vent seals
Vent Seals Weldon Defender Technical Discussions 6 March 16th, 2010 01:24 AM
Vent & Door Seals Question Stmpede Defender Technical Discussions 6 November 14th, 2008 10:05 PM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
Replacing Vent Seals TND90 Defender Technical Discussions 3 January 14th, 2006 08:02 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
