Vent Seal Replacement - Stock to Series step by step - Page 2 - Defender Source
Old June 9th, 2013, 03:23 AM
Thanks guys. Just got the seals and vents and was struggling to figure out where the seals fit.
Old May 23rd, 2014, 05:35 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
I'm doing this right now and I have everything glued in but the vent doesn't close all the way at the bottom, it sort of bulges out. Is this normal, does it settle in with applied pressure?
Old May 23rd, 2014, 06:01 PM
Hopefully ample pretty was applied to the seal while it was curing - that should give you a very tight close, but it shouldn't bulge out much if it was allowed to cure tightly agains the bulkhead. I used a crowbar and the tension from the windshield wipers to keep my vents tight up agains the vent seals while they were curing.
Old May 23rd, 2014, 06:10 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
I wedged some spare 2x4s between the tire and the vent and plan on leaving it overnight, worst case scenario I have to redo it. The top part closes fine but the bottom part of the vent makes it seem like there is just too much seal for it to properly close.
Old May 23rd, 2014, 06:20 PM
So Josh, a year later and no leaks? Seals falling off? My 110 had the Series vent seals and they leaked pretty badly. I need to replace my passenger side seal on my D90 because it isn't seated properly.
Old May 23rd, 2014, 06:24 PM
No leaks and they're not falling off, but the truck is always garaged so it doesn't sit out to see most of the elements mother nature could throw at it. I washed it with a hose a few weeks ago and that would have usually resulted in a puddle of water on both the driver and passenger sides, but they were bone dry afterwards. It certainly requires additional effort/force to get them closed all the way, but even if I fully closed the old ones water would ingress, so this is a huge improvement.
Old May 23rd, 2014, 11:26 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
I have to concur. I did this and wedged a 2x4 between the roll cage bars and added a few pieces of door molding to get the vents forced against the seals, up to the top notch on the inside, left it like that for a few days and they look great and nary a drop on the inside...
Attributed to Shayne...
Old May 24th, 2014, 02:38 AM
Mine are fine. I can't get to the very last notch, but no more water leaks.
Old April 18th, 2015, 05:08 AM
Downunder Bear's Avatar
Downunder Bear
Perry Gamsby
1995 Defender station wagon 300Tdi
Doing it today!
I scraped off the old foam seals from my vents today. That stuff has to be toxic, surely? So far the new rubber seals are waiting to be fixed. I can't be asked removing the flaps from the arm; I know from decades of DIY experience with Landies they will come off easy, but go back on hard. I plan to use a good rubber adhesive tomorrow and fit the seals to the vents, not the flaps.
My car is a 95 300Tdi and I have the rive holding the arm to the bracket fixing the flap, a bolt would be simpler. I will fit the U channel side to the bulkhead and have the vents mate against the raised edge of the seals. I fiugere it is six of one, half a dozen of the other.
The photos show the old and new seals and 'The Ignominy of Land Rover Maintenance'.
Name:	Vent rubber old and new.jpg
ID:	118621   Click image for larger version
Name:	Indignity of Land Rover Maintenance.jpg
Old April 18th, 2015, 09:33 AM
Grover's Avatar
Grover
Greetings Perry!
Keep us posted on the replacement. I will be doing this soon on my Landy.
Our NAS trucks have the roll cage bar in front of the bulkhead flaps making this a more interesting project.
Cheers...
Old April 18th, 2015, 10:47 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
Series scuttle vent seals need to be trained. Initially this is a 2 person job. You glue the seal to the scuttle the you have one person inside pulling on the lever and one person outside pushing against the scuttle vent until you get it fully closed. There you leave the scuttle vent closed for about 4 months before opening it again. By then the shape of the scuttle vent lip has set into the rubber.
TeriAnn
Old April 18th, 2015, 12:51 PM
Grover's Avatar
Grover
Why glue? If they ever need to be replaced seem like it would be a nightmare to remove...
Old April 18th, 2015, 02:44 PM
How else do you suggest affixing them?
Old April 18th, 2015, 04:12 PM
You need some of Jason Lavender's wing top vents
Old April 21st, 2015, 12:37 AM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
This was probably one of the best changes I've done. Mine are now about 10 years old and still work well. Conversely, the old original style were shot within 5 years, and leaked buckets.
"Uhh...I think they all leak like that."
Old April 24th, 2015, 06:01 AM
Downunder Bear
Perry Gamsby
Job Done
I finished the vent rubber replacement today... after 4 days of the worst storms we've had this century. Driving around with no seals at all on the flaps was a worry but actually they leaked less than they used to! I used Tarzan's Grip, a well known brand of adhesive here in Australia; basically an industrial strength super glue, cheap and plentiful.
I took my time and glued one corner, then used cloth tape to keep it in place as I did the next four or five inches. Once the top was done I left it to dry for ten minutes while I did the other one. Once both top edges were in and taped I found the bottom run more or less fell into place. I just ran the glue along the metal and fitted the rubber. I put the flap pins back in and closed the flaps. I'll leave them for 24 hours before seeing if they open and close and seal ok.
I had help from my roof mounted flap holding clamps as I had wisely decided to struggle with the flaps rather than try and remove them. drilling out the pivot rivet and then trying to get one back in would be as problematic as un-doing the hex screws holding the flap to the lever. I fixed them to the bulkhead, not the flap. I have the U channel facing in and the raised edge facing the flap. They close nice and neatly and while I will monitor the corners where it seems perhaps not enough glue was used, I think they will do a good job. Certainly better than the old foam units.
I trust this has been of interest. I still have one more door rubber to fit (rear passenger or 'nearside pantry door' as they call it at Solihull). The other three were reported on at my Facebook page, My Land Rover - No Explanations Necessary'. Please visit and Like, it feeds my ego and it's comforting to know I'm not the only Land Rover tragic in the world. Cheers Perry
Name:	Materials flap seal.jpg
ID:	119108   Click image for larger version
Name:	Hinge rivet.jpg
Name:	Start at corner.jpg
ID:	119110   Click image for larger version
Name:	tape to hold.jpg
Name:	Old seals removed.jpg
ID:	119112   Click image for larger version
Name:	roof mounted flp clamps.jpg
Name:	Flaps closed.jpg
ID:	119114   Click image for larger version
Name:	Looking good like a Defender should.jpg
'Henry VIII' 1995 Defender SW 110, 300Tdi
Previous: 'Wally' 1994 Defender Hardtop, 300Tdi
'Bear Truck' 1993 Discovery V8i
'Dr Dick' 1993 Discovery V8i
'Nigel' 2000 Discovery TD5
'Snorky' 1958 Series II 88" pickup
1953 Series I 86"
1956 Series I 86"
Old May 31st, 2015, 12:48 PM
Grover's Avatar
Grover
Question
I'm replacing mine now. Is this part number PLB332 from Rovers North?
Old May 31st, 2015, 12:59 PM
yep thats them ... have you decided how you are going to attach them>
Old May 31st, 2015, 03:12 PM
Grover's Avatar
Grover
Cool
No, I haven't, but I'm sure I'll over complicate it...
Old May 31st, 2015, 06:53 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
One of the best mods to the truck. Original seals are a joke compared to series type.
ac, series
series front hub seal airbornrover Series Technical Discussions 1 November 12th, 2008 08:48 AM
mostly New Series Parts for sale SafariHP For Sale - Parts 0 July 24th, 2007 09:45 AM
Replacing Vent Seals TND90 Defender Technical Discussions 3 January 14th, 2006 08:02 PM
New D90 Stock Tailpipe 1of40 For Sale - Parts 11 November 19th, 2004 07:22 PM
Stock 90 Parts for Sale Joe B For Sale - Parts 2 October 15th, 2003 11:57 AM
