Vent crankcase breather - Defender Source
Old September 6th, 2014, 12:30 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
How often should this be replace?
Replacing Vent Crankcase Breather.
Weldon
Old September 6th, 2014, 12:52 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Are you referring to the flame trap on the pass side front rocker cover or the smaller vent filter on the rear of the drivers side rocker cover?
Rent my
Old September 6th, 2014, 01:15 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Engine Valve Cover Crank Case Vent - Filter
http://www.roversnorth.com/ProductDe...=ERC248&type=0
Weldon
Old September 6th, 2014, 01:16 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by Weldon View Post
How often should this be replace? Replacing Vent Crankcase Breather.
Sometimes they gum up, usually when the oil loses viscosity it can rise into the breather. Most I've seen are sealed so hard to tell if they are clogged.
I've seen them completely blocked at 80k and spotless at 140k. If there's access I'd replace it around 120k as that seems to be the point when a lot of them stop venting
Old September 6th, 2014, 01:28 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Engine Valve Cover Crank Case Vent - Filter http://www.roversnorth.com/ProductDe...=ERC248&type=0
It's just metal screen in the housing. You should be able to see daylight through it. I'm sure you could clean it in parts cleaner if gummed up.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old September 6th, 2014, 01:43 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
change this out, too
http://www.roversnorth.com/ProductDe...x?code=ERC3209
I've cleaned the flame trap with diesel fuel or carb cleaner and just replaced.
Rent my
Old September 7th, 2014, 09:40 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I have like ten of these
Old September 7th, 2014, 10:32 AM
Has anyone hogged out the little vent tube that the foam insert sits on. It ddoesn't seem like any amount of air can get through. I clean the metal flame trap a few times a year andI am always surprised at how nasty it is
Old September 7th, 2014, 10:45 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I've never *hogged* one out but I have used a small stiff wire to ream it out and clean so it can suck the proper amount of air.
I think Widener had hogged his out and runs a giant vent on his hotrod 4.6
Rent my
Old September 7th, 2014, 12:16 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Thanks all.
Will at least check to see if it needs to be de-clogged.
Weldon
Old September 7th, 2014, 03:17 PM
o its just a 4.6 he does run a big catch can and has explained his pcv set up to me before
Old September 7th, 2014, 07:26 PM
crown14's Avatar
crown14
Verticalscrote
Mike's is a Bosch motor, different PCV design
Old March 22nd, 2016, 10:21 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Should there be a hole drilled in this vent? Or is there just a pin hope I can't see? How does air get in?
Old March 22nd, 2016, 10:24 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Attachment 145631
Very small pin hole with a sponge filter and cap.
I just use a small guage wire and clean it out.
Rent my
Old March 22nd, 2016, 10:53 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Picture of vent opening
Rent my
Old March 22nd, 2016, 11:17 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Picture of vent opening .
Found it with this wire, completely clogged.
Thanks!
Old March 22nd, 2016, 11:48 AM
Grover's Avatar
Grover
Can this be removed from the valve cover to be cleaned? I don't want any muck to fall in the valve cover.
Old March 22nd, 2016, 01:51 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I dont know that it can be removed from the rocker cover.
The vent hole is really small so any gunk that gets pushed inside is inconsequential IMO.
Rent my
Free 300TDi milled side vent and drivers milled side vent Buckon37s Defender Technical Discussions 4 November 4th, 2012 01:56 AM
200tdi cyclone breather/vent line Naplm00 Defender Technical Discussions 4 January 16th, 2012 09:56 AM
New style breather tube!! 48vphantom Defender Technical Discussions 1 August 7th, 2005 09:05 PM
axle breather install CHRIS C Defender Technical Discussions 6 March 22nd, 2005 07:59 AM
Greese fittin an breather toob rover4x4 Defender Technical Discussions 4 December 30th, 2003 11:49 AM
» Defender Registry
110
Rugbier
110
emhewitt110
Add your Defender
