Vehicle temperature question - Defender Source
Old April 8th, 2007, 03:44 AM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
What temp should me D90 run at? I have a VDO gauge, and it was running at 180, but after replacing the water pump, viscous fan and thermostat, it is running between the first and second lines above the 180 mark (so about right in the middle of the gauge). Where should it be running?
Old April 8th, 2007, 09:45 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I run between 180 and 210. Anything above 210 and I get a bit worried unless I am loaded down or something is happening like a long hill climb in hot weather. I don't get really worried till about 215, but definitely shut it down much over that (I don't like to be above 220). Below 180 and it is too cool (at least not optimal). I have seen others that run in the 200-215 range day in and day out, so comfort zones vary.
Old April 8th, 2007, 12:33 PM
oldscratchggf
nate
95 d90
mine is consistantly running at what I would guess to be about 210, which kind of worried me because before it always ran at 180
Old April 11th, 2007, 04:12 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Got a part number on the thermostat you put in? There are a couple different temperature ones available, you may have put in a higher rated part.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 11th, 2007, 09:22 PM
huck1974's Avatar
huck1974
shane cates
94 d90
had the same question although mine seems fine. The factory replacement thermostat I put in was a 195degree. I'm used to a 180 in about everything else I've got. It seems fine though. I didn't even think to ask what temp when I bought it.
Temperature Gague false reading trick? arbik Defender Technical Discussions 67 April 30th, 2017 09:45 PM
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 11:32 AM
Can anybody do a Vin Check for me? Quimbola Misc. Chit-Chat 7 February 18th, 2004 06:24 PM
